Markham Welding Tooth Bar ?
   / Markham Welding Tooth Bar ? #11
Joe, I built the one you see on the IH3444 almost for free with scrap 4140, and 4340 1/2" plate, machined out the teeth, and only had to buy the hardfaceing rod. I welded it up in my uncle's shop with 7018 rod, and rosebud preheating. Took me 3 days to rebuild that bucket's front edge. I decided to put a spade nose onto it. That was almost 20 years ago. The NH TC48DA TB has a 3/4" x 4" bar, and after pricing the steel, teeth, and teeth holders, calculated in my time, which is more valuble now. It was cost effective to just buy it with the tractor. I make a much better salary now than I did 20 years ago. /forums/images/graemlins/wink.gif It does weight quite a bit, and I was surprised when I removed it for the first time.
   / Markham Welding Tooth Bar ? #12
Joe, Do you have a part number for the shanks you used to fab your tooth bar????
Vince
   / Markham Welding Tooth Bar ? #13
My teeth are the 2.25" width, they are also available on ebay, along with the shank holders. I have seen many other teeth, and toothbars with the 1.75" wide teeth, but felt the TC48DA should have the larger teeth. /forums/images/graemlins/smile.gif
   / Markham Welding Tooth Bar ? #14
Vince; Took a while ( I'm so well organized ) I lied... I used 8 teeth for the bucket. Adaptors were #506007, Pins for the teeth were 506105. Didn't give a number for the teeth themselves. They were like a buck a piece.. very cheap. Hope this helps. jr
   / Markham Welding Tooth Bar ? #15
JR, Thank you for taking the time to get me those part numbers. It's greatly appreciated.
Vince
Joe,
By chance do you have Photos of your TB, is sounds like it is exactly like Markham's. Would like to see what your setup looks like completed. I enjoy welding and if I can save a Few Bucks, why not.
   / Markham Welding Tooth Bar ? #18
Deer Hunter;.... Hope you got the picture and comments. If not I will resend.
Joe,
I will be watching my Inbox, have yet to receive anything yet.
New/Unused 13ft X 20ft Single Garage Metal Shed (A54865)
New/Unused 13ft X...
30008 (A53424)
30008 (A53424)
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
