Masonary Lime
/ Masonary Lime #1
pat32rf
Bancroft, Ontario
JD4300
I've just been given a garbage can full of masonry lime, probably type S. We live in an area of acid soil and water, a lot of things such as timothy hay just won't grow, (including deer feed). Is the lime any good for sweetening the soil?
/ Masonary Lime #2
On a similar line, I am interested in DIY lime for my place. Is it practical to use a conical seed/fertilizer spreader for DIY? What type of lime? Is masonary lime ok to spread with this type of spreader? How much per acre?
weedpharma
/ Masonary Lime #3
"Masonry" lime is Calcium Hydroxide.
It's caustic when wet. It CAN be used, but it's not the best choice
"AG" lime is Calcium Carbonate.
It is NOT caustic
National Lime Association FAQs - Frequently Asked Questions
You can easily spread pellitized lime with most types of spreaders, but bulk powdered lime is a nightmare to spread if it's the least bit wet.
It often contains large chunks that will jam a spreader, along with fine powder that a "cyclone" type spreader can't throw
The only real way to know how much per acre is to do soil tests.
The Ph needed is determined by what you're trying to grow.
Around here, it's normal to use at LEAST 1-2 tons per acre, every other year
/ Masonary Lime #4
weedpharma
For us it's just as cheap and tons easier to call the local lime service. It was 60/ton spread and delivered this spring. DIY would definitely be a pelletized thing (powdered is dusty, nasty stuff). Without soil samples, and recently converted from woodland to grass minimum of 2tons per acre, otherwise 1 per.
/ Masonary Lime #5
If you have a wooded area you could spread some there but ware a mask and eye protection because it will burn.
/ Masonary Lime #6
you could use it to make a cordwood shed, they use the masonary lime mixed with sawdust to build with.
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
Brake Drums (A62613)
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
