Massey 1540 Split now won't go togeter
   / Massey 1540 Split now won't go togeter #1
case310350
Split a massey 1540 to repair transmission plug. Now tryp to put back together. everything is level, even. rotated flywheel to align splines. Not sure whats hitting, the pilot shaft and hole or the splines. I get it to go
so it almost meets the top studs, about 1.5 inches but won't go further. Spent about 5 hours so far. May have to call in dealer at 100/hr min 4 hrs ouch. all for a 10.00 plug.
Open to any suggestions.
   / Massey 1540 Split now won't go togeter #2
Take a break then go play with it again eventually it will just slip into place.
   / Massey 1540 Split now won't go togeter #3
Do you have boltwith head removed/long studs in the bellhousing to use to help align the two halves?
   / Massey 1540 Split now won't go togeter #4
Is the PTO drive hanging up? I don't know on a Massey but on some others it goes into a splined hub on the fly wheel.
   / Massey 1540 Split now won't go togeter #5
Check if the inner shaft did engage on the splinecoupler in the gearbox ?
   / Massey 1540 Split now won't go togeter #6
Did you adjust your pedal free play to make sure you aren't bottoming out?
   / Massey 1540 Split now won't go togeter #7
Did you use a clutch alignment tool when installing the clutch disc? The hub needs ot be perfectly centered or you will have a lot of issues trying to get it back together.
   / Massey 1540 Split now won't go togeter #8
Any luck getting it together?
yes, used long bolts so i could see exactly wher i was off.
2015 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
2015 CATERPILLAR...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
NEW Fork Extensions (A59000)
NEW Fork...
HAY SPREADER (A58214)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
