Oil & Fuel Massey 165 won't stay running
   / Massey 165 won't stay running
Thank you, that is very helpful. After sleeping on it, and after your assurance that I can't get it hopelessly out of time, I'm sure I can get it apart if need be and take it somewhere to be repaired. That would be a 7 or 8 hundred $ repair job? Ouch.
After lunch, I'm going to check the supply side again, even though I've checked it twice:) Hope springs eternal.
   / Massey 165 won't stay running #22
Dieseltech nailed it, except there is only one Allen bolt on the gear. You have to remove the oil filler to get at it, then three bolts and the lines. There is also a timing mark where the pump bolts up. Make sure everything else is working before you diagnose the injector pump. It is the expensive part of the fuel system.
   / Massey 165 won't stay running #23
Gengine is correct about allen screw in center, this holds pump hub to drive shaft in pump, DO NOT REMOVE THIS SCREW, remove three bolts that go through gear only, they are 5/16 fine thread that hold gear to hub. My S 90 puller has hex head 1/2 inch size, but some Perkins did use allen heads on gear screws also. Just repaired a 135 pump for fellow in Missouri that he mailed to me last week, is going back in mail tomorrow, was under 200 to repair his. Call me if you have any questions after 7 PM, 574 893 4172. Just make sure hub stays with pump if it needs to come off.
   / Massey 165 won't stay running #24
G'day on the top of your lift/prime pump there is a small bolt/screw remove this and the plate and there is a filter in there, these quite often get overlooked and can cause the probs you are having.
Jon
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
2011 Superior Trailers of Georgia Trailer, VIN # 4M8FZ1629BD000279 (A51572)
2011 Superior...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
