Massey Ferguson 1736 General Thread
   / Massey Ferguson 1736 General Thread
Has anyone added the 3rd function on the loader? If so, what was the cost? And, how do you like it? I'm speaking of the change where the control lever on the loader is replaced with a new one with a switch and the bucket tip channel is then diverted electronically through solenoids to remotes.
Thanks,
LM
   / Massey Ferguson 1736 General Thread #92
Going to be negative teens below zero in the next couple of days so I'll get another reference point. :)
LM
Oh my, you da man.
Please report back how cold it is the next time you start her.
   / Massey Ferguson 1736 General Thread #93
Thanks,
LM
I have one. Cost was built into the price of getting my blade. And I am in Canada so the price would be double that of USA price .
I will check the BOS and see what he marked for a price.
I like it. Works fine. Takes getting used to. I have no previous experience so nothing for comparison. Dealer tech told me it was made by Alo.
LM
Was about -15 deg the other day and I went out at about 10am to fire up the 1736. By this time is had warmed up to just below 0 deg F, and it had been below zero for a few days so the tractor had sat in the unheated pole shed for a week+ without running so it was cold soaked pretty well. I hit the key, the glow plugs cycled and it started. It ran pretty rough for about a minute and I let it run for 15-20 minutes before moving it or working it. I think this is about the threshold on where it would start without some outside heat applied.
LM
   / Massey Ferguson 1736 General Thread #95
LM
OMG, Wow that seems pretty cold to me!
Instead of frying an egg on the engine I'll bet you could have froze a beer in 15 minutes if you sat one on it.
   / Massey Ferguson 1736 General Thread #96
Has anybody else got the backhoe and had headaches with those rear remotes? Since day 1 I have had big hassles with those Safeway qd remotes. Mine are ok most of the time and the loader is only an issue if you remove the arms. Try putting those remotes back in and the middle 2 fight to the death. Just keep pushing Back into the mounting so they won't click in. Had to pull the cover apart so I could werstle the things in. No room to peel back that collar but with inadequate fingertips.
In the back the long main line is an absolute beast to hook to the machines line. It's nearly impossible to pull back the sleeve hold the thing and force the ends together. I'm no wimp in the wrist department either and I do relieve tractor pressure and sometimes push the center in to make sure it's gone.
One of the mounted remotes in the back that goes to the hoe also just loves to pop just slightly loose. If you look at it it appears normal yet it's minutely cocked and sometimes shuts off the rear hydraulics. It's a bit busy back there so the lines aren't always hanging perfectly but it's not like they are really being yanked around either.
So what's the deal with these remotes. Do they really suck this bad? Is there some secret to these , in 3 years I should have found it by now.
Or do they just need to go away.
   / Massey Ferguson 1736 General Thread #97
Drizler, I don't have a backhoe but have always been intrigued by the quick disconnects on the 4-hoses for the front end loader on my 1736.
On my New Holland TC33D the quick disconnects require you to slide the collar back on the female disconnect for the male to go in. To uncouple you must slide the collar the female back.
On my 1736 you do not have to slide the collar back, you just push the male fitting in. To uncouple you just pull on the hose and the fittings separate. The times when I have had problems with these were when I did not bleed all the pressure off prior to connecting them. When I first experienced them when the tractor was delivered I said to myself these will never stay coupled because when you pull to separate them its pretty easy, but I have never had one come off.
   / Massey Ferguson 1736 General Thread #98
I've been reading this thread to see if there was any information as to how or why my 2017 MF 1736 fuel gauge stopped working, it seems these tractor had gauge issues since the start of the 1700 series, I received my new 1736 and the fuel gauge worked until the first tank ran out, I contacted the dealer and they sent a repair person out and he wanted to pump the tank and drop it in my barn, after pumping out the tank he realized there is a check valve between tanks and asked if they could trailer it back to the shop to work on it there, the tractor is there now and I stopped in yesterday for an update, the head tech said the tank sending unit was bad and a replacement was ordered.
   / Massey Ferguson 1736 General Thread #99
Got the tractor back after 3 days and a new tank sending unit, gauge read 3/4 tank and after it when down to empty and was re-fueled it was stuck at one bar once again, dealer said he would look at tractor again, an interesting observation from service people is tank did not need to be dropped, apparently under the running board or foot rest there is an inspection plate to access tank and sending unit, so they say..
   / Massey Ferguson 1736 General Thread #100
Thanks for the update. Oh my, I wonder what the problems is then?
Sterling Dump Truck (A56858)
Sterling Dump...
500 Gallon Poly Tank (A59076)
500 Gallon Poly...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2016 Ford F-350 Super Duty Pickup Truck, VIN: 1FT8W3DT1GFB84319, Crew Cab, 4x4, Steel Flatbed (A59076)
2016 Ford F-350...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
