massey ferguson 35x multipower
   / massey ferguson 35x multipower #1
inishowen
donegal ireland
massey ferguson 35x multi power
well hello everyone could someone please tell me
what kind of oil goes into 35x multipower
thanks
liam
   / massey ferguson 35x multipower #2
Welcome to TBN. :)
   / massey ferguson 35x multipower #3
WELCOME to TBN :)
I moved your thread to the Massey Ferguson Owning/Operating Forum.
   / massey ferguson 35x multipower #4
thanks
liam
I have a 1964 MF 135 diesel with multipower.
I use Tractor Supply Traveller Universal hydraulic fluid that meets MF's M-1129 specification, which is what's called out in the MF135 operator manual. The multipower system uses that same fluid that you pour into the transmission/hydraulic/rear end of the tractor.
Tractor Supply - Traveller® Universal Tractor Trans/Hydraulic Fluid, 2 gal. customer reviews - product reviews - read top consumer ratings
   / massey ferguson 35x multipower #5
G'day and :welcome: don't know what you have available to you but any of the following will work
BP TF 10 or Super TOU
Castrol Agritrans MP
FUCHS UTTO
Hope this help you out
Jon
   / massey ferguson 35x multipower #6
thanks
liam
You can use engine oil, it will be fine, or multi purpose farm oil (TOU) or tractor trans/hydraulic fluid.allwill be ok, however not recommended to use Gear oil ie EP90 or similar.
   / massey ferguson 35x multipower #7
Hi there guys
Never put engine oil in your trans its to heavy and will blow up the hyd pump and do alot of damage tractor hyd/ trans must be used in this situation
Cheers
dave
   / massey ferguson 35x multipower #8
G'day you should not use engine oil in a multipower trans as additives in the oil are not good for the clutch plates in the MP, having said that if you have got a straight trans without MP you can use engine oil it will not harm your hyd pump, they spec 80w90 originally for the straight g/box and it did not kill the pump so a 15w30/40 is not going to worry your pump.
Jon
thanks for all the replys i went to my local oil company and they
advised me to use (shell donnax ta ) as it is a semi automatic transmission
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2020 Kia Soul SUV (A55973)
2020 Kia Soul SUV...
JOHN DEERE 469 BALER (A58214)
JOHN DEERE 469...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
2022 Lonestar 14ft. 5 Ton T/A Utility Trailer (A55973)
2022 Lonestar...
