Massey Ferguson 3650 Transmission problem
   / Massey Ferguson 3650 Transmission problem #1
Calvinotte
Fredericksburg, Tx.
Good Morning everyone.
I'm new to this forum and I have a problem with my massey ferguson 3650's transmission. All of sudden, when operating the tractor in the high range, the Transmission oil low pressure warning light flashes on and the transmission jumps into low range. After driving the tractor in low range for awhile, until the oil gets hot, then everything works okay. I changed the filters, but that didn't seem to solve the problem. What do I look for? What do I check?
   / Massey Ferguson 3650 Transmission problem #2
:welcome:Check under the massey forum, maybe someone there can help.
   / Massey Ferguson 3650 Transmission problem #3
Welcome to TractorByNet!
We moved your thread to the Massey Ferguson Owning & Operating forum. :)
   / Massey Ferguson 3650 Transmission problem #4
It sounds like either an electrical problem or a faulty sensor.
   / Massey Ferguson 3650 Transmission problem #5
When I had that problem trans not shifting from low or moving into low from high it was in the winter when the oil was to thick, when it warmed up it would work, I changed to a Synthetic trans oil then it worked
   / Massey Ferguson 3650 Transmission problem #6
can't get all power to cab so electrical transmission lights will work to shift from low to high but have power for fan radio etc, already changed 50 amp breaker under dash
   / Massey Ferguson 3650 Transmission problem #7
Have you checked the hyd fluid level ? I wouldn't go operating the thing a whole lot until I got to the bottom of this problem. Driving it around in low range "until the oil gets hot" is speculative. It may have nothing to do with temperature. I know you don't want to hear this but if you have plenty of hydraulic oil in it, there might well be
a serious problem internal to the hydrostatic transmission.
2014 Crane Carrier Low Entry New Way 31Yd Side Loader Garbage Truck (A44571)
2014 Crane Carrier...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A46877)
John Deere 5090E...
2006 John Deere 710G 4x4 Extendahoe Loader Backhoe (A44571)
2006 John Deere...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
Godwin CD150S Dri-Prime S/A Towable Dewatering Pump (A44571)
Godwin CD150S...
2017 FREIGHTLINER M2 106 26FT NON CDL BOX TRUCK (A43004)
2017 FREIGHTLINER...
