Massey Ferguson 3650 Transmission problem
/ Massey Ferguson 3650 Transmission problem #1
Calvinotte
Fredericksburg, Tx.
Good Morning everyone.
I'm new to this forum and I have a problem with my massey ferguson 3650's transmission. All of sudden, when operating the tractor in the high range, the Transmission oil low pressure warning light flashes on and the transmission jumps into low range. After driving the tractor in low range for awhile, until the oil gets hot, then everything works okay. I changed the filters, but that didn't seem to solve the problem. What do I look for? What do I check?
/ Massey Ferguson 3650 Transmission problem #3
Welcome to TractorByNet!
We moved your thread to the Massey Ferguson Owning & Operating forum. :)
/ Massey Ferguson 3650 Transmission problem #4
It sounds like either an electrical problem or a faulty sensor.
/ Massey Ferguson 3650 Transmission problem #5
When I had that problem trans not shifting from low or moving into low from high it was in the winter when the oil was to thick, when it warmed up it would work, I changed to a Synthetic trans oil then it worked
/ Massey Ferguson 3650 Transmission problem #6
can't get all power to cab so electrical transmission lights will work to shift from low to high but have power for fan radio etc, already changed 50 amp breaker under dash
/ Massey Ferguson 3650 Transmission problem #7
Have you checked the hyd fluid level ? I wouldn't go operating the thing a whole lot until I got to the bottom of this problem. Driving it around in low range "until the oil gets hot" is speculative. It may have nothing to do with temperature. I know you don't want to hear this but if you have plenty of hydraulic oil in it, there might well be
a serious problem internal to the hydrostatic transmission.
2020 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2020 FORD F-150 XL...
2018 Buick Encore SUV (A59231)
2018 Buick Encore...
9ft. EZ Loader S/A Boat Trailer (A59231)
9ft. EZ Loader S/A...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
1991 International 4900 Box Truck (A55315)
1991 International...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
