Massey Ferguson will not pull or move in gear.
   / Massey Ferguson will not pull or move in gear. #1
Beep383
Decatur, AL
Massy FErguson 1250
I bought a Massy Ferguson 1250 with 669 hours on it and was mowing the yard with a 6 ft fisinish mower and about half way through it just quit pulling no matter what gear I put it in...It seems clutch related...any ideas on what could be wrong....Thanks..
   / Massey Ferguson will not pull or move in gear. #2
I also have a 1250 and, while the tractor will move, especially in low gear, it doesn't have the moving power it had a few weeks ago. I'm thinking it is low on fluid but I can't locate my manual.
I'm searching these posts to see where and wheat type of fluid to put in.
   / Massey Ferguson will not pull or move in gear. #3
If it is a multi range, make sure your not in-between ranges. If its just "floating" between hi and low then its basically still I'm neutral even though you are in gear.
   / Massey Ferguson will not pull or move in gear. #4
It will move,a little. When it gets a little speed it will move right along. When I go up hill with a load it won't move. Is there a clutch adjustment for the MF 1250 or do I have to split the tractor to make any adjustment?
Thanks for your help.
Clem
2014 Ford Taurus AWD Sedan (A44572)
2014 Ford Taurus...
More info coming soon! (A44572)
More info coming...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A43003)
2019 KENWORTH T680...
2016 Ford F-250 Knapheide Service Truck (A44571)
2016 Ford F-250...
2000 FORD F650 FLATBED TRUCK (A43003)
2000 FORD F650...
John Deere 1025R 4x4 Tractor with Loader (A44391)
John Deere 1025R...
