Arc weld
Veteran Member
I bet they would fetch a good price if you ever found one. Then you could give it to your 10 year old.
Whoa! Should be text book stuff there.My father used to have one of the acetylene generators for welding. The white sludge was used to mix with sand to make mortar for building of brick walls.
I used to service control systems in gas factory many years later and remember an accident when one of the generators exploded. There were five generators side by side in the building. Each about 15 feet tall with a pressure controlled variable speed carbide feeder on the top. They never tested safety valves because if they did they usually leaked after the test. I knew, just looking at them, that the safety valves were plugged solid. One day one of the variable drives failed to slow down while pressure in the generator was rising and the generator blew up. The vessel stayed intact but the man hole flange (about 2" thick, bolted by about 20 one 3/4" bolts) flew away and slammed on a big gate valve on the other side of the building and wrapped itself around like play dough. When they pulled it off all the numbers cast in the body of the valve were imprinted in it. The single operator present in the building was killed.
Acetylene cylinder are filled by porous material (crushed bricks) and saturated with acetone. Acetone absorbs acetylene without changing it. That way the acetylene can be stored at 250 psi.
We used to have acetylene (carbide) headlamps for caving. All the serious cavers used them and packed the sludge out with them. Only rookie cavers l used electric flashlights.
Has the advent of LED lights, with much longer battery life, changed that at all?
