Measuring dirt
/ Measuring dirt #1
Pks
Platinum Member
Saline, Michigan
Kubota L3700SU, Cub Cadet 1430, Hustler Super-Z 66in, Vermeer 1250
Is a yard of dirt measured: 3 ft x 3 ft x 3 ft=27 cu ft?
/ Measuring dirt #2
Yes. I love <A target="_blank" HREF=http://www.joshmadison.com/software/convert/download.asp>this program</A>. Really helps when converting Celcius to Farenheit so you guys can understand what I'm talking about.
/ Measuring dirt #3
It is a <font color=red>cubic <font color=black>yard.
/ Measuring dirt
beenthere,
Do I understand correctly; you are saying 27 cubic feet is 1 cubic yard?
If so, then it makes sense since that's what it was in Calculus class. Does the dirt hauling industry have a different value for how much material is in a 1 yard bucket or a 7 yard cement mixer?
/ Measuring dirt #5
when you order dirt or concrete by the yard they will give you cubic yards.
more and more gravel pits are selling by the ton now so let them do the conversion.
when I measure an area I need it for I assume it is packed but when they scoop it up from a pile it is loose so I'll added 10% for air unless it is landscape stone or other material that wont pack down.
/ Measuring dirt #6
Not that I know of, a yard is a yard is a yard. Strictly a volume measurement which is 27 cubic feet. Hard part sometimes is loader buckets are rated in yards by two methods, one with the load "struck" ie leveled off, and one heaped. Well obviously neither is going to be an exact measurement but should get you pretty close. PS concrete is the same - 1 yard is 3ft x 3ft x3ft
/ Measuring dirt #7
<font color=blue>a yard is a yard is a yard<font color=black>
but it is 3 feet or 9 square feet or 27 cubic feet depending if one is talking length, area, or volume
True, that when talking aout a bucket full, or a truck load or a load of concrete, then 'yard' is more of a nickname for volume, as that is the only thing that makes sense.
/ Measuring dirt #8
I looked up the weight of some different types of "dirt".
Loose earth = 75 lbs./ cubic foot or 2025 lbs./ cubic yard
Dry sand = 100 lbs./cubic foot or 2700 lbs./ cubic yard
Wet sand = 125 lbs./cubic foot or 3375 lbs./ cubic yard
Gravel = 109 lbs./cubic foot or 2943 lbs./ cubic yard
Granite = 168 lbs./ cubic foot or 4536 lbs./ cubic yard
Randy
/ Measuring dirt #9
isn't a yard the thing in front and behind my house............
/ Measuring dirt #10
Something like go out and play in the yard. /w3tcompact/icons/wink.gif
/ Measuring dirt
Right before you hear "...get outa my face!" /w3tcompact/icons/shocked.gif
/ Measuring dirt #13
Woody:
Now that sounds like a proper description to me.
What did the English call the tall glasses that were used to hand ale up to coachmen so they did not have to dismount?
Egon
/ Measuring dirt #14
Egon
If the coachmen were drinking tall glasses of ale, they would have to dismount at some point further down the line. Either that or the passengers were in for a rather unpleasant experience.
RonL
/ Measuring dirt #15
Ron:
I'm not sure of the amount but the glass was tall so the Inn Maid could hand it up to the Coachman.
Now as for the Coachman perhaps timming coincided with the horses and no one the wiser.
Egon
/ Measuring dirt #16
If you ever need to estimate the volume of a pile of something (assuming it's a perfect cone which it would only be if deposited by "pouring" from a single point and allowed to form a pile) the formula is 1/3 (pi)r(squared)h
or 1/3(3.14)radius squared(height of the pile). (The radius would be measured at the base of the pile) Pretty useful when getting deliveries of loose product dumped by a dump truck in a single pile
/ Measuring dirt #17
Gerard:
Does this dump truck dump from a perfectly circular orfice at sufficient height to allow the material to fall into a cone coinciding with the natural angle of repose of dumped material?
Egon
/ Measuring dirt #19
Maybe the glass served double duty? /w3tcompact/icons/shocked.gif
/ Measuring dirt #20
egon,
Not any that I've ever seen!! Thats' why it'll be an estimate but should be pretty close. As you intimated it would need to be dropped the way you described to form a perfect cone.....
Kuhn GMD 4051 TL Trail Mower (A64047)
Kuhn GMD 4051 TL...
INOP/NON-RUNNING 2015 International DuraStar 4300 Lab/Chassis Truck, VIN # 3HAMMAAL3FL514548 (A61165)
INOP/NON-RUNNING...
2021 Kubota SVL 97-2 Skid Steer (A61166)
2021 Kubota SVL...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
UNUSED JCT 72" VIBRATORY ROLLER (A62131)
UNUSED JCT 72"...
New/Unused SD Lanch SDLGC100 6-Seater Electric Golf Cart (A61166)
New/Unused SD...
