Metal Building insulation regrets/likes
   / Metal Building insulation regrets/likes #11
Several years ago, but less than 10, I had a 100x100 metal barn building erected. 16' eaves. I bought some of that reflective bubble insulation, maybe 1/4" thick, in big rolls. Had the erection crew install it under the sheet metal roof, before adding the metal sheets. I wanted to reduce the radiant heat nature of the sun hitting the metal. It works and I'd do it again for the cost. The downsides are: (1) some of the tape between the roll edges has come loose, but it can be replaced where needed if I can get up there, and (2) finding leaks can be deceptive. I have twice had to review the roof to try to address leaks. I found screw holes w/o screws and after removing some screws found that not all screws had the neoprene washers for sealing. But that's the installation crew to blame.
Since yours is already up, I would not recommend the reflective bubble - lots of labor (at this point) and keeping it affixed may be extremely frustrating. I'd recommend spray by professionals.
   / Metal Building insulation regrets/likes #12
In 2007, I roofed my barn and installed foil faced bubble insulation with a white underside. It took about 3-4 years and it started cracking and falling. I thought I installed it wrong, until I grabbed the left over roll I had in the put in the rafter area. It crumbled in my grasp. Turns out Mueller Metal warrantied it, but by the time I found this out, it was out of time. Each time I am up in the rafters, I knock all I can reach. It just crumbles to the floor.
hugs, Brandi
   / Metal Building insulation regrets/likes #13
Spray fPam is best, but doesn’t look real pretty after the years go by.
Thanks for the input. I am thinking spray foam for the roof underside, and batting over a radiant barrier for the sides. I need to get estimates and calc the delta twixt all foam vs. the combination of foam and batting. Would prefer all foam unfortunately the solution had to be budget driven.
   / Metal Building insulation regrets/likes #15
Aren't there two types of foam? Is one better then the other? And why?
   / Metal Building insulation regrets/likes #16
Yes, closed cell and open cell. Closed cell is better and more expensive.
   / Metal Building insulation regrets/likes #17
Could you give any details as to why the closed is better? I have a small house that needs to be insulated in the attic. The house has attic rafters , thus a room upstairs, and a tin roof. The Florida sun cooks this place.
Experience counts for a more honest opinion than what a salesman will tell me.
   / Metal Building insulation regrets/likes #18
Water goes through open cell foam and you have ugly things happening like rot, mold, and rust.
All the best,
Peter
   / Metal Building insulation regrets/likes #19
Also, air moves through open cell, significantly reducing the insulation rating.
2018 John Deere 652R QuickTrak 52in Stand-On Commercial Mower (A56857)
2018 John Deere...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2007 Mercedes Benz S550 AWD Sedan (A56859)
2007 Mercedes Benz...
2005 SHOP MADE MANIFOLD TRAILER (A58216)
2005 SHOP MADE...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
Pallet of 10 Chains and 5 Binders (A57453)
Pallet of 10...
