Metal Building insulation regrets/likes
   / Metal Building insulation regrets/likes #11
Several years ago, but less than 10, I had a 100x100 metal barn building erected. 16' eaves. I bought some of that reflective bubble insulation, maybe 1/4" thick, in big rolls. Had the erection crew install it under the sheet metal roof, before adding the metal sheets. I wanted to reduce the radiant heat nature of the sun hitting the metal. It works and I'd do it again for the cost. The downsides are: (1) some of the tape between the roll edges has come loose, but it can be replaced where needed if I can get up there, and (2) finding leaks can be deceptive. I have twice had to review the roof to try to address leaks. I found screw holes w/o screws and after removing some screws found that not all screws had the neoprene washers for sealing. But that's the installation crew to blame.
Since yours is already up, I would not recommend the reflective bubble - lots of labor (at this point) and keeping it affixed may be extremely frustrating. I'd recommend spray by professionals.
   / Metal Building insulation regrets/likes #12
In 2007, I roofed my barn and installed foil faced bubble insulation with a white underside. It took about 3-4 years and it started cracking and falling. I thought I installed it wrong, until I grabbed the left over roll I had in the put in the rafter area. It crumbled in my grasp. Turns out Mueller Metal warrantied it, but by the time I found this out, it was out of time. Each time I am up in the rafters, I knock all I can reach. It just crumbles to the floor.
hugs, Brandi
   / Metal Building insulation regrets/likes #13
Spray fPam is best, but doesn’t look real pretty after the years go by.
Thanks for the input. I am thinking spray foam for the roof underside, and batting over a radiant barrier for the sides. I need to get estimates and calc the delta twixt all foam vs. the combination of foam and batting. Would prefer all foam unfortunately the solution had to be budget driven.
   / Metal Building insulation regrets/likes #15
Aren't there two types of foam? Is one better then the other? And why?
   / Metal Building insulation regrets/likes #16
Yes, closed cell and open cell. Closed cell is better and more expensive.
   / Metal Building insulation regrets/likes #17
Could you give any details as to why the closed is better? I have a small house that needs to be insulated in the attic. The house has attic rafters , thus a room upstairs, and a tin roof. The Florida sun cooks this place.
Experience counts for a more honest opinion than what a salesman will tell me.
   / Metal Building insulation regrets/likes #18
Water goes through open cell foam and you have ugly things happening like rot, mold, and rust.
All the best,
Peter
   / Metal Building insulation regrets/likes #19
Also, air moves through open cell, significantly reducing the insulation rating.
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
207278 (A52708)
207278 (A52708)
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
HUSQVARNA RIDING...
Bunker Rake (A59228)
