Metal chips in trans strainer what's normal?
   / Metal chips in trans strainer what's normal? #11
Re: Metal chips in trans strainer what\'s normal?
My B7510 had a few small shavings in it at the 50 hour maintenance. Seems to be normal for the first cleaning.
Like SeymourBota I used brake cleaner and then blew it dry with compressed air.
Bill Tolle
   / Metal chips in trans strainer what's normal? #12
When I did my 50hr service the strainer was clean. I remember spraying in with brake cleaner. I'm due for 100hr service, lets see how it's looks.
Ray
   / Metal chips in trans strainer what's normal? #13
I had the same experience with my 50 hour service (BX 2200). It was before I found TBN, thankfully I had a brother that explained that this was to be expected. I had nothing on the strainer at the 300 and 600 hour services.
Will
Thanks for the information. I've not had the BX very long it has 360 hours on it and from the looks of the bolt I don't believe the screen has ever been cleaned. I'm going to check it again in 50 hrs.
   / Metal chips in trans strainer what's normal? #15
My B7500 had shavings at 50 hours, and at 360+ it had even more shavings.
According to the B7500 manual it is normal, that's one of the reasons they want you to clean it off.
   / Metal chips in trans strainer what's normal? #16
When I did my 50hr fluid exchange on my BX22 I discovered major filings in the screen. This link details my findings in a letter to Kubota with pictures.
When I removed screen filter, substantial torque was required. The filings were caused by cross threading the screen assembly at the factory. If you see filings this size, check the housing.
Kubota suggested I reinstall the screen assembly and check for leaks. If none, they recommended not to replace the transmission housing (major job of course). They sent me a letter that stated if this area does fail/leak at any point while I owned the tractor they would remedy without charge. Hasn't leaked for 18mos.
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
2010 LOAD MAX 40 FOOT GOOSENECK (A53843)
2010 LOAD MAX 40...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
2013 W-W TRAILER ENCLOSED TRAILED (A53843)
2013 W-W TRAILER...
