Metal-cutting bandsaw blade getting stuck in kerf
   / Metal-cutting bandsaw blade getting stuck in kerf #31
Yup. That's how I do it, if I can. With square stock, there's no way to avoid a flat cut. Likewise, if I'm mitering angle iron. But whenever I can, I try to put the narrow part of the piece parallel to the blade.
I have been using a 14-18 tpi blade, because that's all they have on the shelf at my local hardware store. But I think that I could easily go down to 12 TPI and be okay. As I understand it, you want at least 3 teeth in the blade. 12 tpi should then be okay down to 1/4" stock. I often deal with material as thin as 1/8", but I'd be happy to do 1/8" on the chop saw if I had to, and often I'm dealing with tubing or angle where, even though it's 1/8" thickness, there are two walls, so the total bite that the saw is taking is 1/4" or more.
I have switched to a Lenox 6/8 variable pitch blade and have had great results cutting 1/4 to solid 2" rod with very little deflection.
After talking with the Lenox Tech for about an hour he convinced me to try the 6/8 from my 18tpi and all I can say is wow! What a difference
He told me that the tooth should cut a chip drag it in the gullet and drop once out of the workpiece. I can see the chips now where I used to only see fine dust like particles.
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A57024)
2-Row Peanut...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2014 Ford F-150...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
