Metal Fasteners and Pressure Treated Lumber
   / Metal Fasteners and Pressure Treated Lumber
I have the correct screws for the application, but was concerned primarily about the joist hangers. I read Rat's link at Simpson strong-tie; then went and looked again at what I bought. It's marked ZMAX or whatever, and says it's hot-dipped galvanized but it doesn't appear to be much coating and that's what had me concerned to start with. At any rate it should be dry as soon as the treated 2x4/s dry. I had to build a knee-wall about 32' long to change a 20' section of flat builtup roof to a 36' metal roof span. Used treated 2x4 for the plate against the existing roof, primarily to keep bugs out because some of the decking was waterlogged. I think it'll be OK, and I should have the roofing over it tomorrow. Thanks much for the input!
   / Metal Fasteners and Pressure Treated Lumber #12
<font color="blue"> whatever you do, don't go cheap and use sheetrock screws! </font>
Good point especially since a sheetrock screw or many screws for that matter don't have the shear rating needed for these brackets. Use screws specifically engineered for these brackets or the "Teco" nails.
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
(4) UNUSED LANDHONOR PINS (A54757)
(4) UNUSED...
2010 HEIL TOKEN TRAILER (A53843)
2010 HEIL TOKEN...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
2017 Caterpillar D5 K2 LGP (A55218)
2017 Caterpillar...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
