Metal Fasteners and Pressure Treated Lumber
   / Metal Fasteners and Pressure Treated Lumber
I have the correct screws for the application, but was concerned primarily about the joist hangers. I read Rat's link at Simpson strong-tie; then went and looked again at what I bought. It's marked ZMAX or whatever, and says it's hot-dipped galvanized but it doesn't appear to be much coating and that's what had me concerned to start with. At any rate it should be dry as soon as the treated 2x4/s dry. I had to build a knee-wall about 32' long to change a 20' section of flat builtup roof to a 36' metal roof span. Used treated 2x4 for the plate against the existing roof, primarily to keep bugs out because some of the decking was waterlogged. I think it'll be OK, and I should have the roofing over it tomorrow. Thanks much for the input!
   / Metal Fasteners and Pressure Treated Lumber #12
<font color="blue"> whatever you do, don't go cheap and use sheetrock screws! </font>
Good point especially since a sheetrock screw or many screws for that matter don't have the shear rating needed for these brackets. Use screws specifically engineered for these brackets or the "Teco" nails.
2012 Ford F-150 Crew Cab Pickup Truck (A53422)
2012 Ford F-150...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
