Oil & Fuel MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!!
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #31
could you email me instructions to this also, and maybe part numbers if available. thanks jeremy chapman
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #32
Yes it can be repaired without removing the pump but it must be done in the correct sequence, if you would like to drop me an email i will send you an article showing how to fix it.
Hi JJ
Would you be able to post me info on the above - I would be most greatfull.
Cheers
Roger - New Zealand.
my email - rogatkinson@paradise.net.nz
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #33
Hi JJ
I am new to this site and sent you a message but am repeating it in case it did not work. Would you kindly send info on repairing fuel leak at end of throttle connection on top of injection pump. Most grateful.
Cheers
Roger
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #34
Could you send me the fix for this broble as well, thank you.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #35
Here is my e-mail address. neseirf@hotmail.com
thank you
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #36
Am emailing you separately.
Cheers
Roger
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #37
I have a 165 and a 184-4 wheel drive. The fuel pumps look the same and I believe are the same as on the 135 The 184 has a leak around the throttle shaft. Could you provide me with the instructions on repairing the problem?
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #39
I also have an old JD 420 crawler that I bought nearly 40 years ago. My son is wanting to restore it. The 420 needs a lot of parts. Many of the parts I can make but I still need a source for those that I can't. Where or who has a supply of 420 parts including an engine ?
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #40
I have the same problem with leaking around the throttle shaft. :confused2:
Please e-mail me the instructions too. Thanks, Tony
tmabes425@gmail.com
2017 Ford F-550 Duralift DTAX39 39ft Insulated Bucket Truck (A55973)
2017 Ford F-550...
Black Metal Roof Panels (A55758)
Black Metal Roof...
JOHN DEERE 4 BOTTOM PLOW (A52708)
JOHN DEERE 4...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
