Oil & Fuel MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!!
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #21
Here is more pump information from elsewhere on the internet. Another forum, I think, although I've forgotten exactly where I got it. It contains the instructions for actually rebuilding the pump. This goes far beyond what is necessary to just stop the leaks around the throttle or cutoff stems. I hope that is never necessary, as it seems to involve specialized tooling. You may find it interesting.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #24
I also have a leak, but I am pretty sure it is from a defective gasket. Can someone please send me the instructions for rebuilding the injection pump? I am hoping that I will not have to remove the pump from the tractor to replace the upper gasket, but any help or instructions would be appreciated. Also, any place that sells a gasket kit would be nice too. Please send any information to pottergang1995@aol.com
I tried to download the zipped link provided, but it would not open because it said it was corrupted.
Thanks.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #26
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #28
I'd like to have that article too, same problem right after getting a new paint job. Thank you for your time.
texstar77@hotmail.com
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #29
JJ. in B.C. said:
Yes it can be repaired without removing the pump but it must be done in the correct sequence, if you would like to drop me an email i will send you an article showing how to fix it.
JJ my email is tjohnny321@gmail.com thank you for the info.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #30
JJ,
I would like to have that article on MF fuel leak at inj. pump.
Thanks, redgarc
2017 Liebherr L566 X Power Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel Engine, Cr... (A59076)
2017 Liebherr L566...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2003 Hummer H2 4x4 SUV (A56859)
2003 Hummer H2 4x4...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
