MF 135 Issues
   / MF 135 Issues
Hi All,
I think I am getting the idea about the draft control :confused2:
With the air getting into the hydraulic lines, how do you prime it? I have just got the bucket controls repaired, new O rings and seals, and I thought I may have to bleed the air out of the lines once I re-install it.
I think the idea of a second hand alternator is a good one and will have a look for one when I got to town next.
   / MF 135 Issues #22
G'day Mick to bleed out any air just operate the loader through its full movement a couple of times and this should rid the system of any air
Jon
   / MF 135 Issues #24
After my regulator burned up in a dash fire I put an old one wire alternator on my MF135 diesel. It charges fine at partial throttle or anything above idle. I put in a voltage gauge in one of the many dash holes. Since I don currently have an ignition?? switch I have a separate switch that applies 12V to the Alternator through a fuse. Sometimes I forget to turn the charging system on so will have to get a ignition or accessory\starter switch some day. You can make out the alternator in this shot.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Caterpillar Loader Quick Coupler (A56436)
Caterpillar Loader...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
