MF 135 power steering kit
   / MF 135 power steering kit #11
Brad,
Since the original power steering kit manufactured by HPS (Hydraulic Power Steering) would no way, no how fit my MF 135 with the diesel engine, I ended up sending it back and they sent me one manufactured by A&I (Agricultural and Industrial Products). I believe both companies are located in Turkey. It appears the one from A&I will fit and work fine. There's a little more welding involved than I anticipated, but I have a source for the welding. It also appears to be a bit more robust than the kit from HPS. I'm just waiting for the weather to break before diving into this project (it's cold here in Michigan).
Below is a link describing the A&I kit. Good luck and let me know what you end up with.
Jim
https://www.allpartsstore.com/ItemD...sc=&SearchItem=1&TextSearch=&ItemNumber=MF100
Jim, did you ever get any satisfaction on that ebay kit? I am considering it for my 135 diesel as well. Thanks.
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
2022 John Deere 1025R (A53317)
2022 John Deere...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
Case 1020 25ft Draper Head (A56438)
Case 1020 25ft...
