MF 1428V Will not crank
   / MF 1428V Will not crank #1
Bandit 1953
Humboldt, TN
MF 1428V
My MF 1428V will not crank and keeps blowing the 15 amp fuse in position #4 in the fuse box. Can anyone tell mw where to start troubleshooting this problem?
Thanks
   / MF 1428V Will not crank #2
Does it blow the fuse with the ignition turned, or only when you try to crank the engine?
The fuse blows when you trun the key from the off position to the ignition on position, before you get to the "start" position. The glow plug function is NOT blowing the fuse, they are working OK.
The fuse blows when you turn the key from the off position to the ignition on position, before you get to the "start" position. The glow plug function is NOT blowing the fuse, they are working OK
   / MF 1428V Will not crank #5
I guess my first step would be to check into what fuse #4 corresponds to.
I will check and get back with you. Many thanks
I am not very good with wiring diagrams. The #4 fuse blows when you turn the ignition switch to tje "on" position. I have included the wiring diagram.
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
1986 Value Drop Deck Trailer (A57148)
1986 Value Drop...
(1) 750 / 65R25 TIRE (A58375)
(1) 750 / 65R25...
2017 Ford F-550 (A55973)
2017 Ford F-550...
HYDRAULIC TRENCHER (A58216)
HYDRAULIC TRENCHER...
1974 BUTLER PNEUMATIC TRAILER (A58214)
1974 BUTLER...
