MF 1440 rear remotes
   / MF 1440 rear remotes #1
frankd1
Lucknow, Ontario
MF1440-4 ,MF/GC2610TLB
Hello all, my first post here. I have tried to read as much as I could but have not found my answer.
I would like to put 2 sets of remotes on my MF 1440-4 with loader. It has a fender mounted joystick for the loader fed from the chassis with a 3 hard line assembly.(part# 4266-358-m91) My first question is can anyone tell me the designation of each of the lines as per a schematic?
My next question is, if I order a MF remote kit (part#3708-450-m93). Will that eliminate the hard pipe assembly(4266-358-m91)? Does the remote kit come with everything J need to tie my loader valve back into the hydraulic system.
Thanks
Frank :)
   / MF 1440 rear remotes #2
The MF remote valve kit will not utilize the loader plumbing. It fastens to the transmission and takes hydraulic pressure from there.
You could make your own kit with the power beyond line for the loader, you would need a valve to control it.
Thanks MFRED for your reply. My loader valve takes hydraulic pressure from the transmission now using the hard pipe assembly. Where would the power beyond line be and return line as there are no other ports on the loader valve?
   / MF 1440 rear remotes #4
Can you get a picture of it? It would be easier to identify as there were a few different versions
Here are a few pics of the loader valve and the 3 hard lines coming off of it. Also a pic of where the hard line assembly bolts to the transmission housing.
Thanks
Frank
   / MF 1440 rear remotes #6
Sorry to be a pain but can you get a little better lit picture of the first one
I will pull the rear wheel and get a better pic this week.
Thanks
Here are some more pics, Hope this helps.
   / MF 1440 rear remotes #10
Yes. Those will work. I'll do some thinking. The block usually goes where you're flange bolts on the transmission. I just need to remember how it goes there with the steel lines like you have.
Under-desk Keyboard Tray (A54816)
Under-desk...
1996 International Water Truck with a Caterpillar Engine (A55315)
1996 International...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2024 WITZCO RG-52 LOW BOY (A57880)
2024 WITZCO RG-52...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
2013 Ford F350 (A55973)
2013 Ford F350...
