MF 1547 Four Wheel Drive broken
   / MF 1547 Four Wheel Drive broken #1
jhillvt
grand isle, vt
massey ferguson 1547
While moving dirt yesterday with my MF 1547 I had the four wheel drive stop working. While in four wheel drive the front end makes a terrible noise. In two wheel drive it works fine. I have to finish the job I was working on. Will I do more damage if I just keep it in 2 wheel drive? Second, any idea what I am looking at for a repair cost with the dealer? Thanks
   / MF 1547 Four Wheel Drive broken #2
If it isn't making a noise while in 2wd it should free spool fine and not do any damage. For some reason when the transfer case is engaged to send power to the front end, something is binding causing issues. I have little experience with 4wd tractors but I'd try to engage 4wd and move backwards to see if possible something would clear itself up. Otherwise you're looking at 100 an hour plus travel to be repaired and since it looks more than just the linkage it could be some money. Did you search the site before posting to see if this is an issue others have had?
   / MF 1547 Four Wheel Drive broken #4
I am having the same issue with mine, if you find a solution let me know, and if I find one I will let you know. Thanks
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2004 MANAC 48FT CURTAIN SIDE SPREAD AXLE TRAILER (A57880)
2004 MANAC 48FT...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
