MF 158 3 point lift drifts down
   / MF 158 3 point lift drifts down #1
Baruch Erez
MF 158
A question for you guys: My MF 158 3 points hydraulics lift drifts down when the diverter valve gives pressure to the external component, and there is a load on the 3 point lift. Before I go ahead and try to replace rings on the lift piston, is there something else that may cause it?
   / MF 158 3 point lift drifts down #2
Hi Baruch,
Your thinking is sound to me, but I'm working off first principles not experience on a 158. If it's drifting down after the diverter is switched, then there's a leak between the diversion point up to and including the piston/cylinder. Given the piston/cylinder is the only moving component in those parts, I would look there. I'm guessing that means lifting the top cover. I've lifted the cover on 35 using a chain block, mostly so I could lower it carefully when refitting.
2025 CATERPILLAR 265 SKID STEER (A51242)
2025 CATERPILLAR...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2004 FREIGHTLINER COLUMBIA 112 MID-ROOF SLEEPER (A50854)
2004 FREIGHTLINER...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2005 Morgan Corporation Flatbed Body (A50854)
2005 Morgan...
2017 VOLVO ECR88D EXCAVATOR (A51242)
2017 VOLVO ECR88D...
