mf 165
   / mf 165 #1
carlackerman
Just purchased an older 165--wheer is the oil filler "cap" located on this. It has a Perkins diesel
   / mf 165 #2
:pSitting on the tractor facing the front on the left side near the front of the engine block midway between the top and bottom of the block,It looks like a flat cap with a tee on top you need to turn the tee a few turns to beable to remove the cap.Its right next to the injection pump.:DLarry
   / mf 165 #4
your welcome just remeber to tighten the tee handle backup when your done.I didn't tighten mine up enough once and it came off while using the tractor.:eek:I notice oil on the loader arms and realized what had happened.It was a good thing that I wrapped the block heater cord around it as it kept it from getting lost.:DLarry
2020 ASV RT65 (A60462)
2435 (A60432)
2435 (A60432)
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2022 CATERILLAR 303.5 CR EXCAVATOR (A60429)
2022 CATERILLAR...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
