MF 200 crawler loader, lost forward
   / MF 200 crawler loader, lost forward #11
I know this is an old thread but I'm hoping to get some help. I have a MF 200 Crawler that doesn't have fwd or reverse and was wanting to know who had that pump for $250. Or where I might find one.
   / MF 200 crawler loader, lost forward #12
I'm sure I kept the receipt, and can post a link when I get home. Mine was going on a 2244, but it appears the pump remained the same on the 200.
I did have a bear of a time getting the pump installed. It turns out they changed the bolt orientation, and the pump is half an inch longer, so it wouldn't fit past the starter (and the starter wouldn't fit if you put the pump on first). The original pump has exposed nuts, and the bolt caps are inside (near the input drive that goes into the housing). The new version has the body threaded near the input drive, and long hex cap bolts that are exposed. The problem was that the starter was in the way of the top two bolts.
Ultimately, I took the end cap off the pump, put the top two bolts through it, mounted the pump to the housing, cut slots for the top two bolt holes in a milling machine, slide the cap under the top two bolts, and then put the bottom two bolts in normally. It was about three days worth of cussing, and crying, but I got it done. The final solution was a lot easier than it sounds, and you can't really tell it wasn't supposed to be that way. Anyway, I'll find the info tonight, and post back.
   / MF 200 crawler loader, lost forward #13
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
Mi-T-M 4,000psi Pressure Washer (A56860)
Mi-T-M 4,000psi...
Kubota Utility Cart (A59228)
Kubota Utility...
2018 John Deere 1653 (A56436)
2018 John Deere...
Towable Diesel Generator (A59228)
Towable Diesel...
