MF 2660 Perkins Smoke
   / MF 2660 Perkins Smoke #21
the color issue, as posted, is why I thought of coolant.
heres the thing, a fuel issue CAN put extra smoke out the stack that is SO light it APPEARS to be blue and white.
key is determining if its ACTUALLY got white in the output, mixed with another color.
white alone will NEVER be fuel.
white with other stuff (colors matter, make some kid run behind you with camera) is STILL a coolant issue as long as there actually IS white there.
asking for a friend, you got a dumbass friend willing to run and video stuff?
it would help.
just saying....
the coolant/white issue is not a diesel only issue, same phenomenon carries over into gas engines.
when you've cracked 2 cylinders in a 340hp/455ft lbs tq 322 stroker gas engine and can empty a radiator out your 2 3" tailpipes in 7 minutes you'll know what I mean.
so much white smoke cars behind me on I395 in Bangor,ME pulled over. took me 7 gallons to go 12 miles. ;)
Holy cow Dave! As I said in post #20 this only happened that one day (so far) and by the end of a 2.5 hr operating period it was gone. I'm not at all sure what to expect when I can get on the tractor again. While it was smoking I could have rather easily done a video of it using my cell phone but never thought to do that. Still shell shocked at the time. It was so heavy/dense in the main initial period of smoking it would have probably appeared "white" from 300yds away (where it would definitely have been viewable) but sitting 6 feet from the exhaust tip and the edge of the cloud it fur sure had some blue to it.
As the old Region Service rep said -- the coolant level is going to tell us a lot.
   / MF 2660 Perkins Smoke #23
Just for background context, my Diesel Tech instructor (1968) told the class on about the 3rd day:
Black smoke is unburned fuel
White smoke is low compression or water
Blue smoke is lube oil
Still remember that.....
lpakiz, tell your instructor that if engine lube oil gets burned in a diesel it will cause a BLACK FOG having nothing in the world to do with unburned fuel. That is if it gets in via the intake. I suspect he probably qualified his remarks by saying under what conditions and cases those rules of thumb apply and when they are wrong.
   / MF 2660 Perkins Smoke #25
Our NH gets to smoking now and then. Just run a bottle of fuel cleaner in the fuel tank and it clears up. Maybe once or twice a year. We cut hay and bale with it all summer. Rake with another tractor. Probably 2000 rolls this year. It gets used fairly often.
  • Good Post
Reactions: JWR
When did it start doing that for you? Hours wise. What color smoke?
   / MF 2660 Perkins Smoke #27
It was a royal blue cloud. Starts building about 10 feet above exhaust pipe. Looks like we got our own private thunderstorm going on. But it clears up for several months after a bottle of cleaner.
   / MF 2660 Perkins Smoke #28
I don't know about the hours. There's a half dozen tractors around here, so I'd be lying if I told you.
  • Good Post
Reactions: JWR
   / MF 2660 Perkins Smoke #29
Hello JWR, have you checked the radiator fluid level? Blue/white smoke sounds like maybe coolant in the exhaust. Had that happen, but continuous, not intermittant.
Given the intermittant occurance, I think you may have to resort to the elimination method to see what is left, to home in on this problem.
Good Luck, and please keep us updated.
  • Good Post
Reactions: JWR
Thanks redman. I will definitely be checking the coolant level as soon as I can get back to my farm. I have bored everyone by saying over and again it is 330 miles to my farm and I only get there once a month. In the winter I have fewer and fewer excuses to get there but still do anyway. [My wonderful renters run beef cattle on it and are there several times a week.]
I do not want to overreact but the most senior voices I have heard so far say it could be a head gasket or an intercooler leak of coolant into the intake. I would presume this smoking will get nothing but worse (compared to the first incident described in detail in the orig post.) But I really do not know that. I just have to test all I can think of and then run it a lot more.
Besides just checking coolant level (which I have not done for ages) a local dealer suggested that I get a pressure testing rig from NAPA or other automotive sources and run a pressure test on the coolant system. That I can do myself without hauling the tractor someplace nor removing the belts to watch for bubbles in the radiator, etc. I'm shopping for the kit right now.
Yes sir, I will for sure keep you updated but it is going to take time.
   / MF 2660 Perkins Smoke #31
Yeah a pressure test takes moments to do and is a real useful diagnostic test.
   / MF 2660 Perkins Smoke #32
I think what they’re telling you is, go see if u can borrow a test kit.. I know Advance Auto Parts loans tools .. call around and find out who rents/loans radiator pressure test kits..
They come with different adapters & don’t tell them it’s for a tractor, if u can help it..
Good luck
  • Good Post
Reactions: JWR
One more theory: a local mechanic tells me that some diesels have a small cooler on the EGR gas headed back for the intake of the engine. I have not done the service manual study yet to see if this Perkins has an EGR cooling system or not. Anyone know ?
If there is an EGR cooling system (using radiator coolant circulated through a tiny heat exchanger) it raises the possibility that anti-freeze/water might leak into the heat exchanger in such a way as to accumulate some liquid which might then move with gravity forward or backward in the cavity when operating the tractor uphill or downhill. Seems possible that the leaked coolant gets into the intake more when tilted (one way or the other.) I'm not saying that is what happened but it is the only theory I have heard so far that might account for it smoking only going downhill. Also fits that the first time it happened was a lengthy smoke period (minute or more) and from then on the smoking was more limited and smaller amounts. That would fit with the leaking coolant having pooled, gotten mostly burned off during the first extended downhill driving and then was smaller later in the absence of time to pool.
This theory came from a mechanic who had this (the leaking, not the uphill downhill aspects) happen on a Cummins diesel school bus. On it he has a tiny heat exchanger with a coolant flow leak. We do not yet know if my Perkins on the MF 2660 has such a thing or not.
How on earth to diagnose this (even if it happened to be true) is beyond me. Potentially there is shop test equipment (for tractors like those intended for EGR testing in automobiles) that would show a particular code for a valve failure (stuck open or stuck closed) but probably not for coolant leaks.
Meanwhile I got a radiator pressure test kit to use next time I get to the tractor.
   / MF 2660 Perkins Smoke #34
What airfilter was installed on that tractor ?
A drie airfilter or a oilbath ?
If you overfill an oilbath just a little bit it will suck it into the engine.
Dry. I had just cleaned it out via air pressure recently.
Time for an update: I was able to get to the tractor New Years Day 1/1/23 for a few hours and found the following:
1) Had purchased a cooling system pressure test kit [$58, Amazon] and one of the supplied caps with pump and meter hose connection fits the MF2660 radiator. Ran 45 minute pressure test at 15 psi and there was no drop off in pressure. Stayed the same.
2) Coolant level in the radiator was well above the coils and just as clean and greenish-clear as can be. Surprise since it has been in there for 12 years untouched. It did take about a quart of 50-50 mix to top it off. Obviously going to flush and replace coolant this spring.
3) Ran the engine for probably 30 minutes or so total that day. No sign of smoke (but then it never did smoke last month until I was going downhill...) I did not have it out running in the fields. Will next trip.
4) Took many pictures. Cannot find anything looking like a "thermostart" (someone had mentioned in post #4 ) with wires running to it and relation to the intake.
5) Cannot find the EGR. Spent an hour trying to chase those details in the shop manual and Oper Manual before the trip and could find no ref to an EGR valve or plumbing. Blasted manuals without a good comprehensive index justify shooting the publishers don't they?
6) Oper Manual DOES SAY [in troubleshooting section] that the crankcase ventilation "breather" tube can be clogged and need cleaning and can cause bluish smoke. Stands out like a sore thumb -- why puzzle until I have used that info?? Was not prepared nor had time to dig into that this trip. Must do so of course. Pulling the breathing tube looks like it may take some contortions and time...
7) Next: operate the tractor more to include up/down hill and see if smoke still occurs. Remove and clean the breather tube per manual. Retest in the field. I'll let ya all know when this is done.
7 months later another update:
  • In June using the MF2660 for 3hrs each of 2 days in a row there was blue smoke every time going downhill and once or twice just sitting on the level.
  • Lowering rpm from 1800 to around 1500 seemed to reduce the smoke if not stop it
  • Oil and coolant levels show no change; proper levels
  • Two experienced mechanics have suggested recently that the source is VALVE SEALS.
    • One saying that evidently one or more front seals are bad/sloppy and that is why "downhill produces smoke"
    • The other saying that when the engine is not used often the seals get dry/brittle and tend to let some oil by into the cylinders. I typically use it once a month for a couple of days.
  • Oddly this week I used it for very steep ground bush hogging and misc "weeds" for about 3.5 hrs. with no sign of smoke at all except for one burst of a few seconds.
  • After using it I ran low pressure compressed air into the rocker cover breather tube. When released there was a rush of air pressure release as expected. Have yet to remove the breather tube and clean it thoroughly as the owner's manual suggests but it seems unlikely to be at fault.
  • So far have held back and not used Barr's Leak Stop or similar additives to soften up the valve seals.
8 months later Update:
Still a puzzle ...but it has not collapsed ... yet
  • In August like earlier in the summer I used the MF2660 for 3hrs each of 2 days in a row. Now there is blue smoke SOMETIMES going downhill (quite often but not every time) and still rarely if sitting on the level.
  • Oil and coolant levels show no change; proper levels (though the oil level has been very slightly overfilled for many months since last change sometime on 2022. Long before any blue smoke ever showed up.)
  • These are still the "Prevailing opinions." Two experienced mechanics have suggested recently that the source is VALVE SEALS.
  • At end of August's utilization (~ 8/12/23) I used Bar's Leak Stop oil additive to soften up the valve seals. Not enough time / hours on it since that to see if that will change anything.
  • Even now this thing has only approx. 580 hours on it since I bought it brand new in 2011. Garage kept, regular oil changes, etc.
Any fresh opinions ??
   / MF 2660 Perkins Smoke #39
No, lube oil in a diesel, if burned, puts out some really black smoke, not blueish.
No distinct puffs. It ran the entire time like nothing ever happened. I did throttle down to idle AND up to higher than normal operating rpm during the smoking and could see no change. No missing, no stumble, no change in the smoking.
No. No change in power output.
Not sure about fumes but EGR systems on a VW diesel can put lube oil in the intake and the result is black smoke out the rear -- big time!
No apparent engine oil usage. Checked it after this incident and had checked it a month ago. Right at the full mark, no change.
Amen to that ! Tell me about it! I had a VW diesel start sucking engine oil from the crankcase due to excessive blowby in it's old age. It fogged the entire highway with sooty black smoke for 1/4 mile until I finally figured out what was happening. Key would not shut it down of course and I had to put it in high gear and use the brakes to stall the engine. Thank goodness it was a stick and not automatic! That happens you will never forget it. Using air intake blockage is about the ONLY solution if it had been an automatic. And that never occurred to me so I would have lost the engine if it had been automatic.
Ours put out a royal blue cloud. Looked like we were creating a thunderstorm. Every time we stopped to tie a bale and dump it. Cure is to put motor oil in your diesel fuel.
First, the phrase you quoted from me "...lube oil in a diesel, if burned, puts out some really black smoke, not blueish." was my mistake. That was based on experience using a diesel VW which had so much blowby that it began to ingest and burn it's own lubricating oil from the crankcase -- and that DOES put out the blackest of black clouds. However I now realize that clean lube oil in the combustion process in tiny amounts does produce bluish smoke. OK, that mistake of mine corrected ...
Are you serious -- put motor oil in the diesel fuel !? What does that do? And if that corrects some issue what was the problem in the first place (aside from the visual shock of bluish smoke) ?? Which of your tractors put out the 'royal blue cloud?'
Tks.
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
GIYI VB59-59" HYD VIBRATING BUCKET (A60430)
GIYI VB59-59" HYD...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2423 (A60432)
2423 (A60432)
