MF 35 half shaft collars
   / MF 35 half shaft collars #1
rogert5
sussex
MF 35
Hi all
could anyone tell me the correct way to remove the half shaft collars so I can get to the outer seals on my MF 35?
Thank you if you can help.
Roger.
   / MF 35 half shaft collars #2
Hi all
Roger.
Not sure what you mean by half shaft collars.
   / MF 35 half shaft collars #3
:welcome:
To the forum from Northwest Alabama.
   / MF 35 half shaft collars #6
Press them off.
   / MF 35 half shaft collars #7
I use a SHARP air chisel to expand the old collars, then press off the bearing and collar together
Thank you. Job's done. Split the collars easily but had to make up a thick plate to hold the bearing housing safely as there was not enough showing to press against.
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2010 John Deere 200 Crumbler Seedbed Finisher (A53117)
2010 John Deere...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
2014 Dodge Avenger Sedan (A51694)
2014 Dodge Avenger...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
