MF 3650 Transmission not shifting into 2nd and 4th
   / MF 3650 Transmission not shifting into 2nd and 4th #1
Calvinotte
Fredericksburg, Tx.
Massey Ferguson 3650
My MF 3650 is not letting me shift into 2nd and 4th gear. 1st and 3rd will work. Its also not going into low range. The shuttle shift works fine going forward and reverse. I'm just not sure what to look for or where to look. Any guidance sure would be appreciated.
Cal
   / MF 3650 Transmission not shifting into 2nd and 4th #2
How does it feel when you are trying those gears?
Going into 3rd snd 1st there is a little resistance but trying 2nd and 4rd there is nothing. Like going into neutral.
   / MF 3650 Transmission not shifting into 2nd and 4th #4
Have you checked what are moving when you try engage the gears?
Oh yes, it's like being in neutral.
   / MF 3650 Transmission not shifting into 2nd and 4th #6
Probably some loose bearings, worn synchros, bad shift collar, or ground off gears.
I'd change the fluid and use clean buckets to see what falls out of there. Also, take a peak at what's in the filters. You'll have to cut them open with something besides a cutoff wheel or hacksaw. Those filings will contaminate your test. I use a hydraulic hose cutting blade... Very carefully.
2025 JMR 40in Brush Grapple Skid Steer Attachment (A55851)
2025 JMR 40in...
UNUSED FUTURE CL100 HYD CLAMP GRABBER (A57193)
UNUSED FUTURE...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53485)
THIS WILL BE A...
TANK MANIFOLD (A55745)
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A53422)
2009 Ford F-250...
