MF T035 with bad carburetor. Carter UT
   / MF T035 with bad carburetor. Carter UT #1
toddsgarage
Sandy Lake,PA
JD 1070, MF TO-35
1955 ? ( T0-35 # 157980 ) .4-cyl gas motor Z 134 (618750 ) , Carter UT Carb . I am looking for a carb rebuild kit . No ser.# on carb but it has some casting numbers carter UT. 0-985 On the bowl. on the top flange it has 0-834. Yes it does stall on the hillsides. (keep the tank full it helps ) Should I rebuild if i can find a kit or replace ? what carb should i use. Thanks for your help.
   / MF T035 with bad carburetor. Carter UT #2
Did anyone ever respond to your question. I have the EXACT same situation with my T035 and it seems the float got stuck cause gas was running out the bottom hole of the Carb. So, I removed the carb and disassembled it but now I am in need of gasket and might as well do a complete or partial rebuild.
   / MF T035 with bad carburetor. Carter UT #4
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51691)
2019 Chevrolet...
Concrete Mixer Mini Skid Steer Attachment (A51691)
Concrete Mixer...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2020 Can-Am Ryker Rally 900 Ace 3-Wheeled Motorcycle (A51694)
2020 Can-Am Ryker...
