Traction MF1030 No 4 wheel drive
   / MF1030 No 4 wheel drive #1
tonyta
Spencer,WV
MF 1030
When lever is in 4 wheel drive I have none,it acts like something unhooked? how would you get inside to see?
   / MF1030 No 4 wheel drive #2
I would check and see that the set screw where the 4wd lever meets the shaft is tight. It would be the most likely cause.
Thanks,I was looking at diagram and seen a pin where the inside lever and outside lever connect and thought that pin could be the problem going to check it later thanks for your help Tony
PSI 8 Cylinder Power Unit (A57149)
PSI 8 Cylinder...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2005 Ford Freestyle Multipurpose Vehicle (MPV), VIN # 1FMZK01175GA19616 (A57453)
2005 Ford...
2014 Freightliner 122SD Day Cab Truck, VIN # 3AKJGNDR0EDFL0999 (A57453)
2014 Freightliner...
Maletti BCV3 200 Rotavator (A57149)
Maletti BCV3 200...
Chisel Plow (A57454)
