Traction MF1030 No 4 wheel drive
   / MF1030 No 4 wheel drive #1
tonyta
Spencer,WV
MF 1030
When lever is in 4 wheel drive I have none,it acts like something unhooked? how would you get inside to see?
   / MF1030 No 4 wheel drive #2
I would check and see that the set screw where the 4wd lever meets the shaft is tight. It would be the most likely cause.
Thanks,I was looking at diagram and seen a pin where the inside lever and outside lever connect and thought that pin could be the problem going to check it later thanks for your help Tony
gps trailers (A56859)
2012 CAT 316EL (A55272)
2012 CAT 316EL...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
HELI 5K FORKLIFT (A58214)
HELI 5K FORKLIFT...
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56435)
2018 John Deere...
