MF1528 3PTH not lifter
   / MF1528 3PTH not lifter #11
Found my issue.
The control valve for the hydraulic top link was bearly engage and all the hydraulic flow was going there. It also 1/2 seize , I did put some PB Blaster on it and now it's moving and I have to wigle it to get to the Neutral. Then the 3pth work.
To do a good job I would need to disassemble the valve to clean it. I suspect there is rust,water in there.
In order to do that, I have to removed the rear wheel. not a job that I'm looking for. The tire are loaded and I have chain.
Sound like I would need a forklift to removed the wheel.
Actually, if you keep the loaded wheel-tire vertical it would be no issue. If it leans, you are screwed.
I never removed a wheel that big, your saying to keep it on the ground, removed the bolt. then jack the tractor.
then from there what do I do?
I did not look how is the wheel bolted, is it stud like a regular car or like a volkswagen where the stud screw into the hub?
If it screw into the hub that way I don't have to lift the wheel to get it on the stud.
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
UNUSED WOLVERINE TDB-11-84W 84" BUCKET (A57193)
UNUSED WOLVERINE...
7033 (A51691)
7033 (A51691)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
10' HYD GRADER BLADE (A57192)
10' HYD GRADER...
2005 Kaufman Trailers Car Hauler Trailer (A53421)
2005 Kaufman...
