MF1528 3PTH not lifter
   / MF1528 3PTH not lifter #11
Found my issue.
The control valve for the hydraulic top link was bearly engage and all the hydraulic flow was going there. It also 1/2 seize , I did put some PB Blaster on it and now it's moving and I have to wigle it to get to the Neutral. Then the 3pth work.
To do a good job I would need to disassemble the valve to clean it. I suspect there is rust,water in there.
In order to do that, I have to removed the rear wheel. not a job that I'm looking for. The tire are loaded and I have chain.
Sound like I would need a forklift to removed the wheel.
Actually, if you keep the loaded wheel-tire vertical it would be no issue. If it leans, you are screwed.
I never removed a wheel that big, your saying to keep it on the ground, removed the bolt. then jack the tractor.
then from there what do I do?
I did not look how is the wheel bolted, is it stud like a regular car or like a volkswagen where the stud screw into the hub?
If it screw into the hub that way I don't have to lift the wheel to get it on the stud.
Rotadairon RD145 Pull-Behind Rotary Tiller Tractor Attachment (A59228)
Rotadairon RD145...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
Deere 333E (A60462)
Deere 333E (A60462)
1990 Bayliner Trophy Center Console Boat w/ S/A Boat Trailer (A59231)
1990 Bayliner...
