Mfwd issues with JD 310g
   / Mfwd issues with JD 310g #11
And the toe.
I use 35 psi in my front tires when i inflate ...there is a plug in the tire when i go over 35 psi it loses air . On a new brand tire what is the ideal tire pressure for inflation you would recommend
   / Mfwd issues with JD 310g #13
I’d say those tires are more like 65 psi. What does the sidewall say?
50 to 55 psi would be ideal or use max 65psi?
   / Mfwd issues with JD 310g #16
I like to run max pressure in mine it makes steering easier but running almost half of maximum is definitely going to cause the outside wear faster.
Ok well said thank you for your assistance
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2023 Kubota KX71-3S Mini Excavator (A52377)
2023 Kubota...
2014 INTERNATIONAL 4300 18' REEFER BOX TRUCK (A54607)
2014 INTERNATIONAL...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A54865)
IMPORTANT PLEASE...
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
