Miller mig, what pressure to normally run
   / Miller mig, what pressure to normally run #11
It's all about shielding. If you can run at 12 cfh with no porosity, Turning it up to 24 would use 2x as much gas. If all is running well, Turn it down and save some $$. Your welds will tell you what to set it at.
   / Miller mig, what pressure to normally run #12
This is my take.
And your guage is probabally indeed CFH and NOT PSI.
Basically, take some scrap steel and start turning it down until the welds start to get pin-holes in them (porosity). Then turn it up a tad. Any more is just wasting gas.
   / Miller mig, what pressure to normally run #13
It could be either. My Harris gauge that came with my Lincoln is in PSI but my floating ball gauge regulator, Victo I think, is CFH. I was told that PSI is used for ease of set up since you don't need to flow gas but is not as accurate. I've never had a CFH meter in a round dial gauge, just the floating ball style that requires gas to flow to be set up.
Thanks guys, this gives me a good idea what to run, and save me a little gas also. thanks again. Allan
1991 International 4900 Box Truck (A55315)
1991 International...
yellow ball Trailer (A56859)
yellow ball...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A56435)
2017 Cadillac...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
