Milwaukee 18V impact gun?
   / Milwaukee 18V impact gun? #71
I've been toying with the idea of getting a 3/8 impact along with my current 1/2 inch because I have 3/8 inch impact sockets and the adapter has made it difficult in certain situations. I wish now I went with the 3/8 on my mid torque only because I have the half inch high torque.
   / Milwaukee 18V impact gun? #72
In re-reading this thread, I keep seeing your comments on 3/8", espcially Makita. In my life, 3/8" air tools used to be useless. They are obviously better today but how good are they and how do you use yours? What do you do with it and what is too much for it?
As I said I use mine mainly for the lug nits on a ton dually 4x4. Lugs torque to 160 lbs. and the 3/8 Milwaukee zips them off very easily. Since buying it I have not had any reason to get the 1/2" air impact out... the 3/8" Milwaukee has handled everything. But then I am not doing as much as I did in the past.
   / Milwaukee 18V impact gun? #73
And don’t forget the 12v Milwaukee grease gun 👍🏻
I have the M18 and work the dickens out of it. I'm at the age that I realize the more tools I get, the less time I have. Isn't that backwards?
   / Milwaukee 18V impact gun? #74
At one time, like a couple years ago, the Milwaukee m12 fuel 3/8" was just as strong as the 1/2" version, if not stronger, so that doesnt always hold true..
   / Milwaukee 18V impact gun? #75
You could order the repair part for the size you didn’t have and switch them over from 3/8 to half, and vice versa.
It showed up a few minutes ago and I couldn't wait to open it. Sadly and with deep disappointment I realized the original box was opened, crudely, and had been taped shut, also poorly, and resold to me. I opened the box the Makita package was in, realized what was going on and wife will wrap for return. It's going back. Why would Amazon ship this way and resell returned items as new?
Basically that amounts to a used item at nearly the street price for it. Not for me so I'll advise when I get another from someone local. That would have to be an Amish store and I'm not going that direction for a week or two.
This is why I try to buy local. Sure, local is $20 more but it supports people that also have the odd hardware parts I need.
I hope you're right. Their print on my return days up to 30 days before credit and 7 days to have it posted. They give dates when my credit will hit and it's 30 or 37 days out.
Here it is below:
Your return was dropped off​
Your return is in-transit
Your refund will be issued once the return is processed at the Return Center
We will issue your refund within 30 days from the time you have dropped off your return. Once we issue your refund, it takes up to 7 days for your financial institution to make funds available in your account. A partial or zero refund may apply based on returned item condition as per our policy. Learn more
Initiated
Sep 23
Dropped off
Oct 7
Received
Oct 23
Refund Issued
Oct 30
Refund Credited
I got my credit back to my card today, Oct 4th. So two weeks.
   / Milwaukee 18V impact gun? #77
I like my 3/8” for anything smaller than a 1/2” bolt. It’s way more compact and fits into tighter places. Haven’t tried it on lugnuts yet.
I am going to buy a 1/2" drive impact gun and likely a Milwaukee 18V. Trouble is, I'm confused by the many choices. This is what I think I want:
My use is lighter farm work, mostly for lug nuts and cultivator shovels. I'm tired of dragging around an air hose. I don't want one that's too heavy. Does anyone own this or other 1/2" Milwaukee impact gun that can offer advice or experience?
It would be easier to buy Makita things, because I already own plenty, but I'm not sure the quality is still there.
I'm the OP and that's my original post in wanting to buy a 1/2" drive 18V impact gun for basic farm, auto and tractor work.
After all the very helpful comments and because I had Makita things already, I wound up with the 3/8" Makita 18V and it's perfect for me. I mail ordered from Home Depot after Amazon sent me an open box return I didn't want.
It's lightweight, shockingly powerful and easy on the battery. Just for chuckles I tried on my 150 ft lb Tundra wheels and it zipped them off. no problem. It has multiple power settings so I use the lightest when putting nuts back on and now I can easily hold the difficult "hubcap" in place while installing.
1/2" impact would have been too much for my use. Sure, for tough stuff I would need it and if I still had big equipment it would be a universal tool for all of that and everything else. For that I have a 1000 ft lb air gun so that's my backup. FYI
   / Milwaukee 18V impact gun? #79
I have several Milwaukee 28 volt tools. Don't understand why "M" discontinued them. They are great tools. When you pull the trigger, they work. The 1/2" impact is heavy and bulky but it gets the job done. If it doesn't get the bolt lose, I have to go to the 3/4 sockets and 36" break over. If that don't work, the heat wrench.
For a lot of ag work you're often in an awkward position or arm stretched out and a big tool is too heavy. A great combo with be a powerful 3/8" and a HD 1/2 battery powered. My 3/8" now does lots of things I used drag an air hose out for. No more.
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2017 Ford F-350 Ext. Cab Pickup Truck (A49461)
2017 Ford F-350...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
197359 (A50458)
197359 (A50458)
2015 FREIGHTLINER CASCADIA DAY CAB (A51222)
2015 FREIGHTLINER...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A51222)
2019 BIG TEX...
