Mini Swamp Buggy (base YM146) Help!
   / Mini Swamp Buggy (base YM146) Help! #11
Check the oil, if fuel contaminated, change it and restart, see what happens,
Dave
Thank you... just checkd oil and sure does smell like diesel. got my starter back, guna change oil and put fuel system back together n give it a go. Thanks everyone for the advise
   / Mini Swamp Buggy (base YM146) Help! #13
Post some pictures if you can, sounds like an interesting machine.
Dave
So I gave it another go, Fresh clean fuel. oil change. new filters. fires right up but still only runs for a few mins. I think the fuel pump is on its last leg.... Did research on a "Run away Diesel" and it seems like that's what it may be doing... revs to high rpm. unless I put it in gear it will slow down. still no throttle response though. I am lost I don't know what else to try!
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A58214)
2014 DRAGON...
2010 Specialized Structure 1456 Tri-Axle Portable Office Trailer (A55852)
2010 Specialized...
UNUSED FUTURE FT13CJ EXCAVATOR (A57192)
UNUSED FUTURE...
UNUSED RAYTREE RMBD72 72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
