Minimize rain blowing into open tractor shed
   / Minimize rain blowing into open tractor shed #1
awill99
15 acres Celeste
Mahindra 6500 4WD with Skid Steer FEL.Mahindra 3616 HST with Skidsteer, Vermeer RT200 Trencher
The tractor set the height of the opening and I don't want to put doors on shed.. I am looking for a cost effective method of minimizing the rain that blows in (and we get a lot of it). I have seen the heavy hanging fingers of what looks like leather or rubber in industrial buildings that you can drive thru but I can't find the right search terms to locate them. Anyone found a good solution?
   / Minimize rain blowing into open tractor shed #4
There is also a really heavy woven mesh that I have seen used- it looks very similar to trampoline fabric but it is shaped like a square. These "tarps" have the edges reinforced and have metal grommets or D rings for attachment points. I think Tractor supply sells something similar that they call a "sun shade" that people put over a dog pen. But you can't drive through it- it would have to be pulled back like a curtain or raised like a sail.
   / Minimize rain blowing into open tractor shed #5
Build a larger eve/overhang?
   / Minimize rain blowing into open tractor shed #6
What size is the shed, and would it be possible to pick the whole thing up and rotate it so the opening is on the leeward side of prevailing winds? I have a 12 x 36 shed, one side open, nothing ever gets wet inside. The north is the high/open side - our prevailing winds all come from south - south-east except for a week or two in spring... Steve
Attached is picture. Will look at suggestions and see if I can find good fit. Shed is 28X30 and on the 30 ft side I will install clear siding I already use on a carport.
   / Minimize rain blowing into open tractor shed #9
Just adding sides would do it :)
With sides i won't be able to drive thru it. Attached is better picture. This is and far side is what I am trying to not stop but minimize rain blow thru but still be able to drive thru. TractorShed 5-21-2013 (6).JPG
Survey Kit (A53316)
Survey Kit (A53316)
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2017 Hino 268 26FT Box Truck (A53422)
2017 Hino 268 26FT...
2007 Cat 730 Haul Truck (RIDE AND DRIVE) (A50775)
2007 Cat 730 Haul...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A55788)
2014 Ford F-150...
