Minimize rain blowing into open tractor shed
   / Minimize rain blowing into open tractor shed #1
awill99
15 acres Celeste
Mahindra 6500 4WD with Skid Steer FEL.Mahindra 3616 HST with Skidsteer, Vermeer RT200 Trencher
The tractor set the height of the opening and I don't want to put doors on shed.. I am looking for a cost effective method of minimizing the rain that blows in (and we get a lot of it). I have seen the heavy hanging fingers of what looks like leather or rubber in industrial buildings that you can drive thru but I can't find the right search terms to locate them. Anyone found a good solution?
   / Minimize rain blowing into open tractor shed #4
There is also a really heavy woven mesh that I have seen used- it looks very similar to trampoline fabric but it is shaped like a square. These "tarps" have the edges reinforced and have metal grommets or D rings for attachment points. I think Tractor supply sells something similar that they call a "sun shade" that people put over a dog pen. But you can't drive through it- it would have to be pulled back like a curtain or raised like a sail.
   / Minimize rain blowing into open tractor shed #5
Build a larger eve/overhang?
   / Minimize rain blowing into open tractor shed #6
What size is the shed, and would it be possible to pick the whole thing up and rotate it so the opening is on the leeward side of prevailing winds? I have a 12 x 36 shed, one side open, nothing ever gets wet inside. The north is the high/open side - our prevailing winds all come from south - south-east except for a week or two in spring... Steve
Attached is picture. Will look at suggestions and see if I can find good fit. Shed is 28X30 and on the 30 ft side I will install clear siding I already use on a carport.
   / Minimize rain blowing into open tractor shed #9
Just adding sides would do it :)
With sides i won't be able to drive thru it. Attached is better picture. This is and far side is what I am trying to not stop but minimize rain blow thru but still be able to drive thru. TractorShed 5-21-2013 (6).JPG
34015 (A53421)
34015 (A53421)
Peterbilt 377 Semi-Truck (A55302)
Peterbilt 377...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Wood Chicken (A53316)
3pt 3-Bottom Mold Board Plow (A53316)
3pt 3-Bottom Mold...
