Mixing oil with diesel fuel?
   / Mixing oil with diesel fuel? #11
Re:Mixing oil with diesel fuel-A disaster brewing?
<font color=blue>... I am a very good diesel merchanic ...</font color=blue>
I hate to tell ya... but I think you been had... /w3tcompact/icons/eyes.gif
Stick with what the mfr. tells you to do... and you can't go wrong... going in his direction will only get you in deep trouble... /w3tcompact/icons/wink.gif
Thanks for the advice but I wasn't "had". That's the reason I was asking the question, not to be 'had'.
   / Mixing oil with diesel fuel? #13
I've never heard of anyone doing that except for large fleets. You can buy equipment that cleans the oil and mixs it with the fuel oil in the storage tank. The only benefit is disposing of the used oil. Unless you're using thousands of gals of fuel oil on a regular basis, it's not worth it.
FWIW, diesels will burn a wide variety of oils including cooking oil straight out of the bottle. At $5 a gal it's a bit expensive.
   / Mixing oil with diesel fuel? #14
Think about the metal suspended in used oil.And moisture.Take yer used oil to walmart to dispose of it would be my advise.
   / Mixing oil with diesel fuel? #15
I agree. I think keeping your fuel and oil as clean as possible is the best way to extend the life of an engine. The only time I ever added something to my fuel is when I accidentally pumped two gallons of gasoline into my tank. My mechanic had me add two quarts of transmission fluid and two quarts of engine oil to the tank and then fill it with fuel. I ran out that tank without any problems so I guess the oils counteracted the gas.
   / Mixing oil with diesel fuel? #16
I think the whole concept here is to add back some of the lubrication for the top of the engine and the fuel pump that was lost when the sulfur was reduced. There are some real good products that will do just that without the risks stated above. Check out Redlineoil.com for a product called Plus 85. Works just as advertised. Mark
Thanks for useful info Mark. I knew there was some merit to what this guy was originally saying. Great to see there are products that will replace the effect of the lost sulfur without negative impact on the engine.
Bob
   / Mixing oil with diesel fuel? #18
I've been adding a few ounces of marvel mystery oil to each tank I run. Finally got around to asking my neighbor who's a diesel mechanic what he thought of this, and his take was, can't hurt, but probably not worth the effort.
Sorry to revive the thread. Haven't been around much now that I've got two little ones and a move coming up.
Todd
   / Mixing oil with diesel fuel? #19
Out in the large fleets it use to be common to add used motor oil to the diesel tank after filtering it. But with the coming of the used oil furnaces for the shops, its not as common. There are several manufactures of super oil filters that inject very small amounts of oil into the fuel system and use as a selling point that you never have to do oil changes, just add makeup oil. I personnally recycle my used oil, but I do add ATF with diesel fuel conditioner in my 89 F350, still with the orginial injector pump after 170,000 miles.
   / Mixing oil with diesel fuel? #20
I remember asking a mechanic about Marvel Mystery Oil and he replied It's a mystery why anyone would use that stuff. /forums/images/graemlins/tongue.gif
That was many years ago, the last time I ever bought a can of it.
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
Galvanized Livestock Gate (A55218)
Galvanized...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
2012 JOHN DEERE 644K WHEEL LOADER (A52705)
2012 JOHN DEERE...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
