Mobile 1 15 - 40
   / Mobile 1 15 - 40 #11
If you want to use Mobil One, buy Mobil Truck & SUV. It is just relabeled Mobil Delvac.
   / Mobile 1 15 - 40 #12
If logging, do you mean you'll start the tractor pretty much once, then run it hard all day? If so, 15-40 is prob. OK in your climate. If you'll be starting it more often after letting it cool, get anything synthetic at 5w40. Most wear occurs on startup.
I have an 86 Porsche 911. I've been using Amsoil 10W40 since I got it 3 years ago, except this summer. I ran out of time to change oil last fall, so changed it in May when I fired her up, but couldn't justify the cost of a case of synthetic only to change it again this fall. Therefore, I bought 20w50 Castrol GTX. I sure notice the difference in how quickly the oil pressure builds after a cold start. Porsche recommends a variety of oil weights in dino oil for this year, including 20w50. I'd never use this thick an oil again. It'll be Amsoil 10w40 in a few days. I've been using Mobil 1 5w30 or 0w30 in my Expedition at a quick lube this year (time issues again) with good performance.
   / Mobile 1 15 - 40 #13
Thanks guys. I did look at the JD Syn. It was a blend, not a true syn. and cost $120 for a 5 gal. bucket, and...it was not available in 15-40.
JD says their 0w40 oil is a pure synthetic. And that its made from synthetic base stocks. I don't think that is a blend.
Later,
Dan
   / Mobile 1 15 - 40 #14
JerryG. - If you check the Mobil website you will find the Mobil 1 Truck and Suv is not the same as Mobil Delvac. Completly different oils with different specifications.
   / Mobile 1 15 - 40
"JD says their 0w40 oil is a pure synthetic. And that its made from synthetic base stocks. I don't think that is a blend."
I dunno:confused: ....I looked at a 5 gal bucket at the JD dealership, and it said it was a blend. The parts guy agreed that it was, and that was all they had for syn. oil.
   / Mobile 1 15 - 40 #16
If that is right show me the page. Up until a few months ago (3-4), they had both spec sheets up on their site and they were the exact same.
   / Mobile 1 15 - 40 #17
When Mobil showed the spec, I copied them to excel. I thought that I had lost them, but here they are if I can post them. I don't know if Excel can be posted or not. Well so much for that. I will try posting a picture of it. I don't know what is wrong.
I have a meeting before noon and work to do this afternoon. Tonight I will post this silly thing IF I can get it to work.
   / Mobile 1 15 - 40 #18
From the mobil website.
Mobil 1 Truck and SUV and basic description. Note that they state in bold red "Note: This product is not recommended for diesel engines. Use new Mobil 1 Turbo Diesel Truck 5W-40 for diesel engines." Also note that this oil is only API rated for SM, SL,SJ,EC,CF,CD. This oil is found in their automotive car/truck section of their website.
Mobil Delvac conventional is API rated CI-4 Plus/CI-4/CH-4/CG-4/CF-4/CF/SL/SJ Mobil Delvac synthetic is API rated CI-4 PLUS/CI-4/CH-4/CG-4/CF-4/CF/SL/SJ. Note both of these oils also meet Cummins, Caterpillar, Detroit, Ford, Global and JASO diesel spec's. These oils are found in their commercial/industrial engine oil section of their website.
   / Mobile 1 15 - 40 #19
I knew that there was some changes talked about a while back. The Mobil One Truck and SUV 5-40 was the same as Delvac when I copied both specs off of the site. I have 5 gallons of the 5-40 synthetic that says it is CI-4. That is the oil spec that I copied off of the Mobil site that showed it as the exact same spec as Delvac synthetic. It looks like if you have the 5-30 you have a light duty oil and if you have the 5-40 you have Delvac. More games to mess with people.
   / Mobile 1 15 - 40 #20
Come on now. You didn't expect them to leave it the same for more than a month did you? That would be to easy on us. :)
I checked the specs on the Mobil 1 Turbo Diesel Truck 5W/40 and it looks like it has the same spec's as the Delvac synthetic. So they must have renamed the original Truck and SUV oil to Turbo Diesel Truck and made a new formulation for the Truck and SUV.
Don't worry. By the time you figure out what they changed it will be different next month.
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
