Modern appliances, grumble, grumble,
   / Modern appliances, grumble, grumble, #21
Great thread!
All the LEDs light my way thru the house at night too. I wish there was a way to turn them off.
We recently moved and had to get a new fridge, it's a Samsung with a control panel on the door. When it was delivered the panel didn't work and the door was replaced. I am hoping I get 10 years out of it but I think I am dreaming.
Everything these days is made to last 5 years or so it seems. I do my best to find old stuff before I consider buying new anymore. Heck I just picked up an old Cat 1 Dearborn plow and disc that need a little love but are mostly in fine shape.
   / Modern appliances, grumble, grumble, #22
When I sat with my engineer to build my current retirement house, he flat out told me to get all Bosch or Thermador commercial units
My Bosch range has done well over the last 2 years- but the first year was tough. A extended warranty thru Sears was rendered useless as they didn't have a repairman that could fix it. First one they sent exclaimed "Umh, I've never saw one of those before" - boy, doesn't that give ya the warm & fuzzy feeling! Finally Bosch stepped in and repaired it, Thanks Bosch!, and I've got a new $800 control panel setting in stock for the next time it happens.
   / Modern appliances, grumble, grumble, #23
For a washer and dryer I decided to go with Speed Queen. The technology is "outdated" (toploader) but the machine has all steel gears, almost zero plastic, and according to the salesman is designed to be run every day for the next 20 years! The fact that Speed Queen is the brand that many laundromats use was a big selling point for me :thumbsup:
Jonny, if you bought a Speed Queen for less than $1000, you got an Amana washer. Commercial Speed Queens are $1500 to $1600 for the top-loaders. These machines have simplified cycles (only 4) and no gizmos like fabric softener dispensers or soap dispensers. Their simple cycles and heavy duty construction are what made them common in laundromats.
Through high school and my first few years in the military, I found laundromats and fixed Speed Queens for the owners. The designs have changed radically because today's washers have direct drive transmissions and don't use belts, clutches, etc. that the old washers did. Even the consumer grade washers have a swing-up front cover for easy servicing and inspection, but the added complexity with non-heavy duty construction means the home washers cannot compare to the true commercial grade machines.
I have a Speed Queen/Amana dryer and used to have a top-loader washer. My biggest problem with that washer was that the tub seal started leaking after just one year. I got it replaced under warranty and then it started leaking again a few years later. At that point, I replaced the washer.
   / Modern appliances, grumble, grumble, #24
Hmmm, yet very high end stoves like commercial units are still mostly mechanical...looks like "consumer grade" stuff is where the junk is.
I know where there's a gently used Wolf range for $500. The only electronics are the clock. It's one of the old standing pilot light models, so nothing you can't fix with a wrench and a screwdriver.
   / Modern appliances, grumble, grumble, #25
Just to chime in on the other side, I remodeled my kitchen in 2005 and installed all new appliances. They have been trouble free except for the magnetron in the microwave, which burned out, probably because I was boiling half a gallon of water at a time. The dishwasher is so quiet you can hold a conversation in the kitchen, the refrigerator is so well insulated it only uses a fraction of the electricity, and the range is self-cleaning with a full size conventional/convection oven and a smaller pizza/cookie oven above it.
   / Modern appliances, grumble, grumble, #26
My son has a 3 year old Maytag Washer, front load...I walks and does a dance with med loads. He had the top off to check the springs and braces. the Inner workings, mainly tub appeared to be made of bolted together Nylon or some type of hard plastic. he is sick of the noise this machine makes while running?
   / Modern appliances, grumble, grumble, #27
All front loaders should be placed on a stall mat or similar material to eliminate vibration transfer, especially if they sit next to a gas dryer with a flex line. Front loaders are sensitive to balance as well, I've had best luck when the front is 1/16-1/8 inch higher than rear and left to right is dead on.
   / Modern appliances, grumble, grumble, #28
I need another coffee too!
Somewhere here on TBN I wrote up a spoof about Vacuums as "house tractors", I wonder if I can find it... It was a trifle funny...
Mostly I am a worry wart. I LOVE our new appliances, but I fear they will not last.
Same with my new car, I LOVE LOVE LOVE it, but I'm not sure I can see it still driving in 25 years. My buddy had a computer problem in his mini-van recently and it was messing up the throttle, turn signals, tranny, weird stuff as he was driving even! He replaced the computer motherboard... it got a little better...
I was also grousing about the underlying attitude of "disposableness = goodness".
I'm just being negative today. I promise to shape up...
Be well,
David
PS - It is very cool to have a Buddy in Scotland...:thumbsup:
It's very cool indeed, my blood almost turned solid when I stepped outside this morning.
Update:
The guy who runs a local appliance parts store walked me thru a troubleshooting process and it came down to either the temp probe or the clock (I presume "clock" means some kind of board, since I see no reason why a clock would control temp). Set for 350, the oven kept the broiler burner on well beyond 350 and went to 649 by the time we shut it off.
Since the probe was $34 and the clock was $219, he suggested to start with the probe. Made sense to me. But his parts book shows 2 screws holding it in and we don't have screws or screw holes. So you have to pull the stove out and get to it from the back. That leads to complications from the way it is installed and I gave up and called a repair guy.
FWIW, the model # prefix is 790 and the repair guy says our "Kenmore" is a Frigidaire. I wonder if there is a list somewhere telling who makes what based on model number? Didn't really want a Kenmore but there were only a couple makes and models that would fit.
   / Modern appliances, grumble, grumble, #30
Update:
The guy who runs a local appliance parts store walked me thru a troubleshooting process and it came down to either the temp probe or the clock (I presume "clock" means some kind of board, since I see no reason why a clock would control temp). .
Yeah, the "clock" is the PCB that has the clock display mounted in it.
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
Massey Ferguson 9250 (A52748)
Massey Ferguson...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
