PaOkie
Can anyone give recommendations on a good moldboard plow. Likely will be using it with an 55 hp tractor? Thanks
Yes. Get an old one. I like the old Ford 101 plow. You could pull a 2 or 3 bottom. Make sure it has trip protection, either shear pin or spring protection. Should find one for $300 to $600. Don't waste money on a new one, like a Leinbach.
Thanks for the info. So here is a brief rundown of my tillage plans. I will be planting about three acres initially with raised beds and plastic mulch. Ground is currently pasture. So thought is use a mold board to turn pasture followed by a disc harrow and finished with a chain harrow then come in with the bedder/mulch layer. One item I am struggling with is whether to use a disc or a tiller. I am leaning toward the disc but appreciate opinions on that.
Well I guess I could write a lengthy dissertation about how poor the land is in Montana when all the OP wanted was tractor size information.New Member ZOEDOG: I see thirteen of your T-B-N posts are one sentence; two are two sentences, including #5.
Thanks for sharing.
