Montana 5740
/ Montana 5740 #1
okchuck
NE OK
I've been looking at the Montana 5740. Like everything I see but I'm a little concerned if it has enough power to run a 10 foot pull type Bush Hog. The dealer tells me the tractor is rated 52 hp at the PTO. The Bush Hog manual calls for a minimum 50 PTO hp so I'm sure it would run it, but what I am really worried is that I couldn't mow as fast I want with the Montana.I'm currently using a 95 hp Ford to pull the Bush Hog , it never bogs the engine but sometimes I have to slow down in thick weeds and brush to get a good quality cut. I would like to hear anyone's advise on the 5740 and a 10 foot Bush Hog'
/ Montana 5740 #2
Thats one **** of a mower for that size tractor, it would be all that tractor would want...I would want at least a 65-70hp tractor.
/ Montana 5740 #3
I pull a 3pt 10ft cutter. I mostly clip pasture and weeds, but have cut some thick Johnson grass. The tractor does a fine job handling a 10 footer. I was initially concerned about the weight making the front end light. I leave the FEL on but take the bucket off. I live in Middle TN and have climbed some pretty steep hills while cutting and never felt the front get light. I run in 1st gear (high range). This is the same speed I use to pull my old 6 ft cutter. Its fast enough to get the job done but slow enough not to beat you to death.
/ Montana 5740 #4
IMHO 50 pto hp is the minimum for a 10' mower. That said.. minimum is fine if you aren't running a race or 'clearing' tree-lings.
Soundguy
/ Montana 5740 #5
</font><font color="blue" class="small">( I'm currently using a 95 hp Ford to pull the Bush Hog , it never bogs the engine but sometimes I have to slow down in thick weeds and brush to get a good quality cut )</font>
Hmm.. I'm using a similar setup.. 90ish hp ford with a 10' mower.. I mow in 5th (high).. and tend to get a decent quality cut no matter what I go over. How fast are you mowing? What's the condition of the blades? Perhaps it's time to dress the blades?
Soundguy
/ Montana 5740 #6
I live just east of Edmond and you are welcome to come do some mowing on mine. I have a 7' rotary cutter that I use with my 5740C and it never slows down unless I hit something really hard. I am planning on buying a 15' towable batwing mower in the future once I get the johnson grass converted to grass. I mow about 25 acres and a 7' mower is not enough - takes too long - but it does chew up the gnarley stuff.
/ Montana 5740 #7
I must be a novice, but a 10' brush hog on a 50hp PTO? I admit I don't know a lot about mowing with a brush hog. I use a 7' HD mower behind either a 52hp or 70hp PTO and get good results, but I don't think I'd consider a 10' mower. I think a 10' mower would be all the 70hp PTO could handle. Do we tend to push the machines beyond their limit?
/ Montana 5740 #8
Yeah for that HP a 7ft is about right...actually would only recommend a heavy duty 6ft...and 8ft at MAX...but that just my recommendation...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
IRanch IRMC High End Massage Chair (A60463)
IRanch IRMC High...
1999 John Deere 7810 (A60462)
1999 John Deere...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
John Deere 1518 (A60462)
John Deere 1518...
2022 Komatsu D61PX (A60462)
2022 Komatsu D61PX...
