Morton ploe barn-How square should it be ????
   / Morton ploe barn-How square should it be ???? #11
It doesn't sound like Morton. And I'm sure they'll make it right.
Remember in school A squared plus B squared equal C Squared?
If you want to check square on a corner pull some measurements on two intersecting walls. Three four five is a good one. Measure down three feet down one wall, make a mark. Measure down the other wall four feet, make a mark.
It should measure five feet diagonally between the marks.
You can use any variation of this, six eight ten etc.
Laying out a slab or fence is much easier this way than the old move the diagonal technique, especially if like me one is working by himself.
You take each side and multiply it by itself. Then you add those two numbers together. Sixty by a hundred foot would be thirty six hundred plus ten thousand. The square root of thirteen thousand six hundred is one hundred sixteen feet and six tenths of an inch. That's your're diagonal measurement.
Working by yourself you'd find one plane. Let's say it's the hundred foot line and you want that line to be parallel to the road, the house, whatever. You make those marks a hundred feet apart.
Then go out sixty feet as close to perpidicular to the hundred foot line as experience and common sense will allow. Make a mark. From the opposite corner or hundred foot mark pull off one hundred and sixteen feet and six tenths of an inch. Where the sixty foot mark and the diagonal one meet is your squared corner of that end of the building or fence.
To find the last corner measure down one hundred feet from your found corner and up sixty feet from the far corner. You can do a double diagonal measurement for excerise or self satisfaction. It will be dead on.
If you do this with a kid that's having problems in math in school but he loves making things. He or she will find a whole new reason to pay attention from now on in math classes. /forums/images/graemlins/grin.gif
If like me your math teacher was an old gal you could call this a "biddy ditty".
   / Morton ploe barn-How square should it be ???? #12
I WOULD NOT let them pour concrete at all!! , until all issue are resolved. I would also take alot of pictures and a video with friends and family in it showing the problems with my building. There is a chance that these are not Morton's employees installing your building but a contractor that installs building kits for Morton pole buildings. You need to find out who the men working on your building work for. If it is an contractor, he does not want to rebuild at his cost, neither does he what Mortons Pole Building Inc. to hear about his poor workmanship. When your complaints are known, they will start blaming each other for the problem and you will become the overzealous owner, demanding your version of perfection, that where the pictures and video come in, copies can be sent to corporate to show you are not making a mountain out of a mole hill. Morton Pole buildings does have a fantastic reputation in southeast MI, That's why they get a premium price for there product. Happy hunting, for the solution to the problem
   / Morton ploe barn-How square should it be ???? #13
Myself, for a project costing this much, I would pay an expert to come in and evaluate what is there. I think the advice of everyone so far is right on.
For me, paying $500 or whatever it took to get an unbiased opinion in writing from someone with credentials would be well worth it. It would first confirm that I was seeing things properly, and second it would give me a big bullet to shoot at whomever I needed to.
This would be in addition to getting the local building inspector out asap.
I would act immediately without delay. Let the expert make the measurements need to verify out of square conditions and so on.
I also would not pay a penny more until the situation was resolved. And I would not permit any further consitruction (like was mentioned, don't pour the concrete(! ) until the current questions are resolved.
"I'm not an expert, but things still look wrong to me. However "MR. X " is an expert, and his evaluation is that this building has not been put up properyly for these reasons...here is his report...make it right or see you in court..."
Hopefully it would not have to get to that point...but it sure can't hurt to have some formal backup to your position when a building that costs this much is the issue, and you will have to live with it for a long time...
PS...an expert is not just a guy from out of town...It should be an experienced architect or perhaps a professional engineer...
   / Morton ploe barn-How square should it be ???? #14
Don't do anything further on the building until you have everything fixed. Especially not paying a dime more!!!!! Get the Morton sales person out and tell/show him what you think is wrong. Contact the home office of Morton and complain. I had a Morton building in the past and was very impressed with their quality, workmanship, etc. You pay a premium price and you should get premium work. Morton does not want the bad publicity, and will not allow substandard work to be performed by their employees. Even if they have to take down and remove roofing panels, etc. they will do what ever it takes to make it correct. If they used just sand or pea gravel for the footers somebody screwed up BIG TIME. Where were the local inspectors out to check to make sure they used concrete? If no concrete was used it sounds like they took major shortcuts. With the extreme cold temperatures in Michigan I'm assuming that the frost line is much deeper than here on the east coast. It should not have even gotten this far with such poor quality workmanship. Keep the pressure up and contact the home office.
   / Morton ploe barn-How square should it be ???? #15
My building is within a .25 of square, these guys were good. One of the crew also builds BIG bridges so he HAS to be good and he carries his professional ethics to his private work.
On the building, they would be tearing it down, packing it up, and heading out of the county...........you have heard of shotgun wedddings, this would be sort of like that, only I would be divorcing this contractor. NO reason for half the problems you see, and if they let it go as is..............that would be very sad.
TAKE PHOTOS NOW. Everything you see make sure to document with photos, and if needed video, such as the door thing, show that on video. Take your own measurements and photo record them also. This sounds like either a sloppy job done with hired contract help, or they are going on your inexperience and hoping to get it done. You might also contact the BBB, your local contractor unions, local building codes enforcement folks, the folks that financed this, if so, etc. The more you folks you have wondering about the quality of work they do, the more ammo you have to get some results.
   / Morton ploe barn-How square should it be ???? #16
When you communicate with the contractor or Morton HQs, make sure you send your letters either certified, return receipt, or registered. If this problem gets to court, you will need to show not only that you outlined your problems but that the appropriate entities received your letters. If you get the contractor or salesperson out for any discussions, follow up with a certified letter outlining what agreements or discussions were held.
Do not hesitate to send the first notice that there are problems and you want all work stopped until the problems you outine are resolved.
I think I would wait for an assessment from a professional engineer until after I had my first round of discussions with the contractor/salesman and Morton HQs (early next week?). If you get a feeling they will not resolve your issues, then go for the professional engineer's opinion.
Ok guys here is a update. The salesman called me this am after getting a phone message last night. He took my list and drove out to the barn. He was very concerned about what he heard. The flag pole will be set in concrete as it should be when the slab is poured. The dead bolt needs to be fixed on the door. The crawl space in the ceiling instead of the gabled wall had to be put there or they would have had to cut the center of a truss. Don't ask why they didn't know that when they wrote the bid and the contract. /forums/images/graemlins/confused.gif He does not feel the beams are separating other than normal warpage etc or is any different from what he normally sees. I will be up to meet him Wednesday and I will take some photos to post. In short of the small issues were easily resolved. He does not feel the roof is uneven but instead feels that it is a optical illusion and it may be. I had a neighbor come over who has a pole barn and look. He thought it was uneven as well. We looked at his and it looks straight as a arrow. The gaps on the OSB were " more than he would like to see". Of course when I hear that all I can think is I am paying more than I want to pay ! I decided to think about that until we meet on Wednsday. He told me there needs to be some gap in case the OSB swells. I nearly fell of my chair because the OSB on the other side is very tight. So we are going to have to look at that. He does not feel any of the trusses are twisted etc. I am only concearned about 1 I can see. Wednsday I will take a ladder and put a level on it. If its not plum I will be hiring a profession building engineer to completely inspect everything. Now for the clincher. The beam I was worried about the most that does not touch the sidewall is out of spec. He says they must have hit it with the tractor before the concrete in the footings set. I am guessing they used sackqrete. Ok no problem stuff happens. Here is where I start to get upset. I hired the TOP DOG. Even when I was a kid and we built stuff we would check it with a string. Now they have laser levels and all kinds of goodies to make the job quicker and easier. Why the heck didnt they knock that footing and beam out and replace it before they put the sidewall up ? Clearely they knew it was out and were going to pour the concrete with out saying a word. Concrete is on hold now. They will remove the beam and footing but to do so they must remove a good portion of the sidewall and brace the truss while the work is done. I'm hearing concearns of causing more problems than they fix. I guess my whole position at this point boils down to if that truss is level or not when I check it. If it is then we certainly have problems. If it is not and it is just the one beam then I either want a discount or the work fixed. I will have to closely inspect the other beams. I think one other is slightly twisted all though not nearly as bad.
   / Morton ploe barn-How square should it be ???? #18
Hi Docsknotinn,
First of all, let me say that I admire your careful measured response to this debacle. You will get a lot further than if you simply "blow up." Keep the pressure on the home office, and I concur with others about getting the inspector out there. The "explanations" of the Morton folks so far are transparent, weak excuses for a poor job.
On the matter of getting a discount or fixing it, I would be especially cautious. IMHO, a "discount" should only be considered if the amount of the discount is at least equal to or greater than the cost of materials and labor which would be required to make it right, as calculated by a bona fide estimate by a qualified individual.
The way I look at it is that a building that is not up to spec on Day 1, can at the best stay the same, but more likely it will deteriorate over time. If you ever plan to sell, a buyer will surely discount the value steeply when he/she conducts a pre-purchase inspection. As financially attractive a discount can be initially, its value will pale over time. I would opt for insisting on getting exactly what you are paying for-- quality product and quality workmanship. My $0.02: They screwed up, and they should make it whole again on their own nickel.
Please keep us posted...
Well it's 4 am and I certainly can't say I'm not loosing sleep over this. When I went up the other day I was not prepared for this so I didn't have a square, a level, ladder etc. I still believe in the main garage there is another beam that is off but not as badly as the one I spoke about with the sales person. The problem is there are 8 more beams in the 24 x 24 insulated room area that I can not really see. The room is lined with OSB. On one sidewall there is a single seam that does not line up nearly as well as the others. I would guess one panel sticks out 2/8 of a inch but that is just a guess. It really bothers me that they are offering to replace the one beam it but indicating at the same time it may create more problems than it fixes. The other thing I keep going back to in my mind is the roof line. All of my neighbors barns have 1x4 purlins that run across the top of the trusses for the roofing to screw on to. My plans call for 2x4 purlins. I don't think there are any there at all if they are what I am thinking of. The metal roof is only screwed to the trusses which are 6' on center. I am leaning very hard towards calling a civil/structural engineer to inspect the building.
   / Morton ploe barn-How square should it be ???? #20
I would pull a string to see if the roof were straight and flat. Put a 1/2 in piece of wood under the string on each end and pull it tight, this way it will not simply follow the roof. I do not buy that by replacing the one beam they will be creating any problems unless they already know that more things are wrong. If the contract says purlins I would make sure they are up there. And if the access door is in the wrong place as specificed by the contract that is there problem have them re engineer it and put it where it was called for. I think you may need to move a little higher up the Morton chain to get this done right.
2003 STERLING ACTERRA ROLLBACK (A51222)
2003 STERLING...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
2005 MERCEDES-BENZ C-Class (A50324)
2005 MERCEDES-BENZ...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
