Most expensive watering can I've ever seen
   / Most expensive watering can I've ever seen #1
robs660
Washington NJ
Kubota B20
Did some spot seeding along the road and also added some new dirt to a few low places. It is over 300' to the nearest hose spigot so I decided to add another function to my B20. I am guessing that I hold about 60 gallons and the whole drive is I flat pavement so I'm not worried about tipping or spilling. Worked so well I just ordered a 12v pump so I can do more with it. I am sure this will lead to a trailer mounted tank but for now this is the best $10.00s I've spent in a long time.
   / Most expensive watering can I've ever seen #2
Whatever floats your boat- or I guess in your FEL in your case. :thumbsup: Now that I think about it, how about putting an air hose in there and then it could be a moble Jacuzzi!!!
   / Most expensive watering can I've ever seen #3
Good idea, I use my bucket to haul water.
   / Most expensive watering can I've ever seen #4
It works just fine. Not sure why a tarp is needed...buckets don't tend to leak.
I use my bucket on the backhoe to fill a stump hole with water if the stump doesn't want to move. Next morning it is like it is rooted in warm butter rather than hard clay.
   / Most expensive watering can I've ever seen #5
keep on tractoring! it works right?:tractor:
   / Most expensive watering can I've ever seen #6
Why the tarp? I have carried water in mine, it doesn't leak.
   / Most expensive watering can I've ever seen #7
I have a 55gal plastic drum set up with a hose bib. I either put it in the loader or RTV when remote watering. The loader works better because it siphons quicker with more height.
I have holes for a tooth bar and holes where I mount my snow plow to the bucket so I would loose water real fast without it. I guess I could put bolts with a little silicone but the tarp worked good. I like the hot tub idea. My 3 year old would love that
   / Most expensive watering can I've ever seen #9
Keep life simple. Tapered wooden plugs have been used for decades to plug holes. If you have a pocket knife and a dry oak limb you're in business. :D
   / Most expensive watering can I've ever seen #10
Dang good idea. Thanks for the tip.
2023 DOUBLE DRUM ROLLER (A55745)
2023 DOUBLE DRUM...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2015 CASE 580N (A47477)
2015 CASE 580N...
New Paladin 30" Backhoe Bucket (A50775)
New Paladin 30"...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
