Most expensive watering can I've ever seen
   / Most expensive watering can I've ever seen
Wooden plugs. Why didn't think of that. Time to spend some quality time with my lathe
   / Most expensive watering can I've ever seen #12
I wouldn't dream of showing my whittled pocket knife plugs to anyone but since you have a lathe we gotta see pics of yours. While still on the lathe just before the parting tool and in the holes please. :D
   / Most expensive watering can I've ever seen #13
Another redneck bathtub!!!! :D You should get in it and take a bath and have someone take your pic, man that would be hilarious!!!! :laughing:
I upgraded the whole system. Got rubber lugs for the holes. Mounted a 2.6 gpm pump and refined the whole thing. Works great!
   / Most expensive watering can I've ever seen #15
I have a 55gal plastic drum set up with a hose bib. I either put it in the loader or RTV when remote watering. The loader works better because it siphons quicker with more height.
I've done something similar with a 32gal tank and soaker hose. I'm buying a 12v pump as soon as it comes in the local Fleet Supply. They are out at the moment, but are very good at ordering anything I need. Meanwhile, gravity works. Slow but effective.
Joe
My pump was $90.00 at tractor supply company. It took me about 15 minutes to bend up the bracket to hold the pump. I did realize I have to scale down the hose diam to get more pressure and distance. It's a work in progress
   / Most expensive watering can I've ever seen #17
I would recommend you keep the hose size larger to minimize friction loss, add a proper nozzle on the end for the spray pattern of your choice.
   / Most expensive watering can I've ever seen #18
According to mr. Bernoulli:
Slow flow = high pressure
Fast flow = low pressure
You want a large hose for delivering volume but a small orifice will slow it down no matter what you do.
Think of it like a drawer slide... the more stages you have extending the slower the ball bearings move and the easier it is to pull. Same thing with larger hose diameter. The shear between flow lamina are less for the same flowrate as a smaller hose.
20 Ton Hydraulic Bottle Jack (A55787)
20 Ton Hydraulic...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
2012 Dodge Journey SUV (A53424)
2012 Dodge Journey...
2015 Ford Transit 150 Cargo Van (A55788)
2015 Ford Transit...
