Motor oil and other fuel additives
   / Motor oil and other fuel additives #31
Geeez....Just go to TSC or Wally World, get your Power Service, dump it in your tank and be done with it.
oh come on, i know better than to dump an emulsifier in my tank ;)
stanadyne, baby!
   / Motor oil and other fuel additives #33
stanadyne, baby!
Where did you find that PowerService is an emulsifier??? :confused: Im not argueing, just curious is all.
technically i'm wrong, it isnt an emulsifier. but from what i've read it acts the same as far as the way it handles water.
   / Motor oil and other fuel additives #35
Hmmmm OK well i dont really know. it has worked well for my BioDiesel and well heck it is already hydro......(whatever the word is for able to absorb water) i run waterblock filters at every container exit point. I may have to mix up some PowerService White and water and see what happens :rolleyes: :rolleyes:
do what you want.
i chose a demuslifier because of what it does with water. i started the research when i bought my duramax pickup.
probably a lot less of a problem with a TRACTOR, but i dont know. i'll stick to what i know is good. plus, i get it at a good price locally.
hygroscopic
   / Motor oil and other fuel additives #39
So what did this test prove? Nothing in my opinion. They did not mix it with fuel. They should have added fuel, water and additive for it to be a real test. Chemical compounds can change and combine when these additives are added to fuel.
i think it was a good little test. what was the most important for me was the real-world SOTP meter.
is it as important for tractors? dunno.
if you guys like PS, that's great. i happen to not.
is it THAT friggin important? probably not! truck/tractor will run good either way. i left this thread to die, because i didn't think there was anything else that could be pulled from it.
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
2016 Ford F-750 14FT Flatbed Truck (A52377)
2016 Ford F-750...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
